Install l-t-d fasteners on new tonneau - Tips?
Lbp
I purchased new tonneau and hood stick covers for my '58 TR3A. They are "british vinyl" and come with a bag of lift-the-dot fasteners for me to install. I've poked around, but haven't found much on this subject. Does anyone have any tips about installing the fasteners on the covers? I did get the hole punch tool.
Thanks, Bill
Re: Install l-t-d fasteners on new tonneau - Tips?
Bill
I just finished that exact exercise on my 59 3A about 2 weeks ago.
I think i did find some advice on this forum that worked well. Take your time, and mark a centerline on both car and covers. Start from the middle and work you way out. Put the covers in the sun so they are warm and stretchable. For the tonneau keep working between back and front.
The punch makes it much easier.
The punch only makes the center hole and usually a craft knife or scalpel is needed to jab tiny slits for the 4 x fixing tabs. Depends on the tonneau material.
Viv.
What they said..plus you can use a soap stone to mark the point for the holes.
Plus.....leave the vinyl out in the sun to soften it and make it easier to stretch. Work center out, front to back, side to side, one snap at a time.
Gordon
vivdownunder said:
The punch only makes the center hole...
I've never used one but apparently some punches do the complete set of holes. Wish I had bought one 30 years ago, but I still use the hole punch and Xacto knife.
I mounted the whole cover first using just the center holes stretched over the studs. This allowed me to make sure I liked the fit right (the size of the dots covers small mistakes in the hole location).
If you then press the lift-a-dots down snuggly, they leave an impression on the vinyl. I finally slit the vinyl at the impressions using an exacto. The tool looks pretty neat...it looks like the cover has to come off the car each time to use it, though.
John
Thanks for all the good advice. I've already purchased the above-pictured punch from Moss.
Bill
Lin BT7 rear seat fasteners and install Austin Healey 7
SherpaPilot TR6 New Ammeter Install Question Triumph 5
D TR4/4A TR4A top install details Triumph 12
S TR6 Windshield Install Triumph 11
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 9
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
E Heater install Spridgets 2
algot1901 Roof install Other British Cars 16
A Spitfire Install fan Triumph 1
S Install drain cock in radiator. MG 2
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
6 Master Cylinder Install Spridgets 5
S MGB Transmission cross member re-install MG 14
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
K TR2/3/3A Brake caliper piston install? Triumph 18
EWD TR6 Top Install Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
R side light install Spridgets 2
R TR2/3/3A Install new wiring harness in steering column Triumph 16
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
EWD TR6 74 TR6 - Handbrake handle reinstall Triumph 2
J Tips for quarter elliiptic spring install Spridgets 3
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
EWD TR6 Trunion Install Triumph 0
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
66healey BJ8 shifter spring install Austin Healey 2
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
VelodromeRacer BJ8 Shifter reinstall Austin Healey 4
C How to install Stone Guards on driving lights? Austin Healey 7
F Heater valve/tap gasket- Install dry? Austin Healey 10
Csarneson BN4 Cam Gear Install Austin Healey 3
Rut 5 speed install Spridgets 14
R More Shroud to Scuttle install Austin Healey 4
R Dash Install questions Austin Healey 31
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
J TR2/3/3A Trunnion Install Triumph 3
B TR2/3/3A Cigarette Lighter Install Triumph 7
D Prepping to install engine Spridgets 2
P BN2 new wood steering wheel install Austin Healey 5
C MGB Paint first or install mechanics MG 10
T TR4/4A Rear Seatback/Hoodstick [Top] cover install Triumph 0
D BT7 Timing chain install Austin Healey 2
