ID for 1275 with no tag
owby
Member
My 65 sprite has a newer 1275 engine with no id tag. Anyone know how to identify it from "landmarks"? It has a timing chain cover with a "can" attached for the crankcase breather. Thanx--Owby
jlaird
On the side of the engine there is a clock thing cast in, it gives cast date.
Jer 1275 ID Tag ? Spridgets 2
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Rut How much does a 1275 weigh? Spridgets 8
