Horn Relay
Shawn
I have just purchased a 1976 Triumph TR6 and the previous owner had installed a Mountney steering wheel. The horn on the car did not work so I checked and found the brush component was missing. I have ordered and received that part but don’t know how to make everything work. It appears that all I have to do is screw in the brush component into the hole at the base of the steering wheel but there’s obviously more to it than that. One more thing, the brush component I received appears to be too long to fir correctly under your horn push. What length should the brush be?
Do you have any detailed instructions on mow to make your horn push work in this setup? I would greatly appreciate your help.
Rick O.
Shawn--The brush is supplied in 2 lengths: 2.6 (Moss 142534) and 3.4 (Moss 142534X) inches. Perhaps you have the 3.4 length and should return for the 2.6. Also, make sure the slip ring and relay are in good order.
Rick O.
The slip ring is a cylindrical black piece of plastic with a brass surface for the brush to ride on. A wire attached to the brass completes the low voltage circuit to the horn relay when you depress the horn button. The relay is attached to the left front inner wing with a pair of screws/nuts just ahead of the wiper motor. Hope this helps.
Sopwith_Camel horn relay wiring Jaguar 3
R Horn relay Spridgets 2
P TR6 TR6 Horn Relay Problems Triumph 8
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
S TR4/4A Horn relay Triumph 2
T TR5/TR250 TR6 Horn Relay Triumph 1
Gerry M TR6 Horn Relay Question Triumph 4
S replacement horn relay Triumph 9
mabbott TR6 TR6 horn relay? Triumph 1
KVH Horn Relay Triumph 10
Stinger TR4/4A TR4A Horn Relay Triumph 1
KVH TR4/4A TR4 Horn Relay Triumph 2
B Horn Relay or O/D Relay Triumph 16
Jim_Gruber Horn Relay Spridgets 19
R How to connect a horn relay Austin Healey 2
KVH Horn Relay Switch Triumph 1
P TR6 Horn issue 1974 TR6 Triumph 5
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
S Indicator / Horn Switch Austin Healey 10
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
