TR4/4A TR4 Horn Relay
KVH
There's a horn relay, three pronged, near the right horn and carbs. Sometimes my horn won't work, or there's a delay, and it seems that is related to insufficient current from the generator. The problem is only on low RPMs.
So I ordered a new horn relay from Moss. It looks different, but I verified the part number, and even reordered one after the first one didn't appear to work.
I now have my old relay back in and it works the same as ever, with some issues on low RPMs.
Does anyone know why the Moss one wouldn't work? I'm certain I had the wiring correct, but I'm wondering if I have to add a ground and make some other adjustment.
thx
angelfj1
The voltage produced by DC dynamos(generators) is diretly proportional to the speed of the rotor. Theoretically there would be no limit to the voltage produced if there wasn't a limit to the speed at which it could be driven. That said, there is a minimum voltage that your dynamo should produce even at low speed, e.g. 2000 rpm or less. To maintain a proper voltage TR's (and other cars so equipped) depend on a control box with a simple relay which regulates the voltage. At lower rpm it is possible that insufficient voltage is being produced to operate the horn relay so that it's contact close and make a low resistance connection, completing the connection to the horns. There are a number of possibilities:
1. control box needs adjustment
2. bad connections resulting in low voltage at horn relay , horns or both.
3. bad connection in horn push.
4. dynamo service required, maybe brushes need replacement or commutator needs to be turned down.
5. horns are out of adjustment or contacts dirty or corroded, requiring higher than normal current
This is a very simple process of elimination. If I had to guess, I would suspect the horns, and/or a bad connection somewhere. Start by checking all of the connections including the earth connections for the battery and dynamo. If the problem is not corrected at this point check the horns and finally the control box and dynamo. You should be able to find all of the diagnostic tests in a good shop manual.
TR3driver
Great Pumpkin - R.I.P
Personally, I wouldn't even be looking at the charging system at this point. The horns should be able to work from just the battery! Of course, it wouldn't hurt to check what your battery voltage is doing while the horns are sounding, but if it was that weak I expect you'd have trouble starting the car as well.
I'm not sure how TR4A horns are made, but the ones used on TR3/A have a pushrod through the center that operates the points. If the pushrod gets cruddy or rusty, or even if the points are slightly out of adjustment, the horn may refuse to work at lower voltage. In fact, I need to pull apart the low note horn on my project TR3 as it won't sound reliably on just battery voltage.
But I agree entirely about the bad connections being likely suspects. I fought what I thought was a bad switch for a long time on the 3A (which had no relay originally) before I finally discovered that the 4-way bullet sleeve at the LH horn was broken inside and not making good contact.
If the Moss relay had 4 terminals, then you probably need to jumper the extra terminal to the hot terminal, rather than ground. The switch grounds the terminal that it connects to, and the coil needs voltage across it to activate the relay. But most automotive relays will work reliably to down under 9 volts, so I doubt that low voltage is causing problems with the relay itself.
BTW, TR4s did not originally have relays, so I assume we are talking about your 4A ...
KVH TR4/4A TR4: The Horn Problem Again Triumph 2
TR4nut TR4/4A TR4 horn trouble - a common complaint. Triumph 8
KVH TR4/4A Triumph TR4/4A--The Horn Triumph 2
A TR4/4A Next.....TR4 horn ??? Triumph 7
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
