TR4/4A Triumph TR4/4A--The Horn
KVH
The wiring and grounds on my horn are fine--at least I've convinced myself of that. But I still have problems.
Here's what happens: On initial start up it often just makes a single click sound, and often does the same thing when it is sitting with the engine off or while I'm at a slow idle, like at a light.
But while driving, or after a long drive, it works fine 90% of the time.
There seems to be a connection with the operation of the engine. Could it be the horn relay? For $20 I could get a new one. thx
Bugeye58
[ QUOTE ]
[/ QUOTE ]
That sounds like normal operation for any LBC sub-system!! /ubbthreads/images/graemlins/grin.gif
Have you checked the voltage at the horn? Is it the horn itself that is making the click noise, or the relay? Clean all the relevant connections and see what happens.
Of course, make sure the battery is in good shape, and the generator output is correct.
It sounds as though there is high resistance somewhere in the system that requires the added voltage of the generator running at speed to properly operate things. If you tried to operate the horn while the generator was only putting out minimum charging voltage, that could explain the 90% operation.
Jeff
kindofblue
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]\
ROFLMAO /ubbthreads/images/graemlins/wink.gif
Why pull your hair out over something that works most of the time?
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
S For Sale Triumph TR4 Factory Parts and Service Manuals on CD/ROM - 1961 - 1965 Triumph Classifieds 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
N For Sale 1964 Triumph TR4 street racer Triumph Classifieds 0
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
B Triumph TR4 replacement fuel tanks Restoration & Tools 3
T TR4/4A 1963 Triumph TR4 Triumph 11
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
V TR4/4A Triumph TR4 A clutch assembly and gearbox Triumph 6
Stinger TR4/4A 1967 Triumph TR4-A FOR SALE Triumph 9
Triumph_TR4_Girl TR4/4A Second Hand Copy of Original Triumph TR4 Triumph 1
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
CZ_Dave Triumph TR4 Spotted 0
J TR4/4A Triumph TR4 Body Restorer Chicago Area Triumph 3
Atomic8 TR4/4A 1965 Triumph TR4 For Sale - $17,875 Triumph 4
M TR4/4A SVRA NJMP Triumph TR4 in-car Triumph 3
Tabcon TR4/4A Triumph TR4 T3T4 Turbo Charger Kit Triumph 3
C Triumph TR4 racecar build [w/ detailed photos!] Racing 2
3798j TR4/4A A Golden Triumph TR4 Triumph 10
Cabrioman TR4/4A History of the Triumph TR4 and the Surrey Top Triumph 10
glemon TR4/4A Complete Original Triumph TR4-6 Triumph 10
SCguy TR4/4A Triumph TR4 Oil Pressure Triumph 26
SCguy TR4/4A TRIUMPH TR2 TR4 DOOR RESTRAINT ASSEMBLY Triumph 1
Tim Tucker TR4/4A Book Review Request: "HOW TO RESTORE TRIUMPH TR4" Triumph 5
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
