TR4/4A Triumph TR4 Oil Pressure
SCguy
As I continue to "break in" my engine on my TR4, I continually worry about low oil pressure. Once warm my car has about 38-40 lbs. of pressure at about 2500 rpms. I hear that this is about right. Can someone explain to me why the TR4 engine has or needs less oil pressure than my TR6? At idle it has about 15 to 20 lbs.
TR3driver
Great Pumpkin - R.I.P
Does seem kind of low to me, for a freshly rebuilt engine. What grade of oil are you using ? Have you checked the gauge for accuracy ? And how on earth can you read the difference between 38 psi and 40 psi on the stock gauge ?!
40 psi @ 2500 rpm won't necessarily harm anything; oil pressure is primarily an indicator of wear. Oil flow is what is important to the bearings and the pressure doesn't tell you much about flow. But I would expect a fresh engine to open the pressure relief valve (ie 70 psi) at 2500 rpm hot.
Have you tried cleaning the relief valve ?
TR4nut
Larry-
Yours does sound low, I run about 60 psi@2500 cruising speed when warm, and drop to about 35-40 at idle. I did have some erratic pressures, pretty 10-20 psi at idle, but I believe that was due to a misbehaving bypass valve. Might be worth seeing if your gauge is really giving reliable numbers even though it is rebuilt.
Randy.
prb51
I've a TR3 but same engine, as you know, and the official service supplement manual with the later "full flow" oil cleaner (bypass) says one should get 70 psi @ 2000 rpm at 70 deg C. Now that's not really hot as that's 158 degrees.
On my 3 (how many miles?) if the engine is still at 158 I'm 70 psi. It will drop to 50/55 psi after lengthy driving when fully hot (20-30 miles of driving) but I suspect this is a viscosity issue more than anything (castrol 20-50).
For a 'fresh engine' that seems a bit low.
What do your start up numbers look like (mine 70 psi at 1100 rpm, 50 psi 500 rpm Idle)?
SCguy
SCguy
My start up number are at least 70 psi at 1100 rpm, 50 psi 500 rpm Idle (like yours). These numbers stay high until my car has been running for about 20 minutes. Then they seem to quickly drop to the new levels and stay there.
I have a spin-on oil filter and adapter and have not yet checked the bi-pass valve.
Merlin63Tr4
Larry, your oil pressure does sound a little low for a newly rebuilt engine. On my well worn '63 (90,000 miles since last overhaul) I'm still getting 70 psig at normal operating temperatures and about 2000-2500 rpm. I'm using 20W-50 viscosity oil and still have the standard canister filter setup. This last summer I did have an incident with sudden low idle oil pressure after getting off I680 after a very long high speed run, and it turned out to be a small piece of debris in the oil pressure relief valve seat not allowing the valve to fully close. My normal hot idle oil pressure runs around 40 psig, but them my idle speed is around 850 to 900 rpm.
I did verify that my oil pressure gage is accurate by comparing it against a lab calibrated gage.
TR3driver
Don't recall where I read it now, but ISTR someone writing that they found their oil pump outer rotor to be cracked, which caused both low oil pressure and damage to the pump housing. If you don't find any other cause, it might be worth dropping the pan and inspecting the pump.
Bob_Burt
Have you tried adjusting the pressure relief valve? When I got my '58 TR-3 2 years ago the oil pressure was running about 90 # warm. I think it's the original engine with about 90 K miles. I backed-off the valve a couple of turns and it now runs at 70 # on the highway.
Maybe your valve is set too low? Simple thing to check - just back off of the nut and turn the plug in a turn or two, then check the results.
Bob Burt
prb51
Messing with the valve won't raise low oil pressure. It's preset to open at 70 lbs. at the factory and that's its only function.
Bob was correct to lower his so it opened at 70 lbs but that's all it will do.
You can't improve low pressure by 'tightening' things up as it were.
tdskip
Too much oil pressure - now thre is a problem that I won't have to deal with....
vrod
SC guy, This past summer, I was talking to a guy who said he had to take his oil pump apart and check the clearances between the pump parts and file part of it down in order to obtain the right clearances. After he did this, he said he had great oil presure. You would have to hear from one of our other tr4 owners, to see if they have had to do this before. I am used to dealing more with the I6.
prb51
SC,
You could always drop the pan and check tolerances, change out the big ends, redo the thrust bearings.
I'm going to do that just as maint.
Darrell_Walker
But it is possible that the bypass is malfunctioning and only allowing 40 lbs of pressure before it opens.
SCguy
SCguy
prb51 said:
SC,
Sorry for my ignorance... What are "big ends" and "thrust bearings"? Are those the "Main Bearings" and "Thrust Washers"?
This would be new ground for me, so can anyone point me to a good write-up or get me started.
In the meantime, I'm going to continue to try and put some miles on my car in the hopes of getting a better feel for what's going on.
SCguy
SCguy
Except, I get higher readings until the engine fully warms up.
TR3driver
"big ends" is British for connecting rod bearings. And on a TRactor motor, I wouldn't even bother checking the thrust bearings/washers ... they will be fine. It's only the TR6 motor (which inexplicably has much less thrust surface than the TR2-4 motor) where the thurst washers are an issue.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]This would be new ground for me, so can anyone point me to a good write-up or get me started.[/QUOTE]Try the Haynes manual, ISTR it had a brief desciption of changing the con rod bearings with the engine in the car. Plus a suggestion to do it as preventative maintenance every 30,000 miles or so (which IMO is a good idea).
To check the clearance, you disassemble the bearing and lay a piece of Plastigage across the face. Then reassemble, torque, and disassemble again. Compare the width of the crushed Plastigage to the bands on the wrapper to read the clearance. Plastigage should be available at any auto parts store. You'll probably want some of both .001-.003 for main bearings and .002-.006 for rods.
A quick Google turned up this article on using Plastigage (on a Ford V8, but similar to a TR)
https://www.fast351.com/cartech/enginerebuild/index4.htm
TR4nut
I really like this topic and if you don't mind would like to ask some related questions-
If it is a worn bearing that is leading to the pressure issue Larry has, is there a likely culprit or are all bearings suspect? Just checking the big ends of the connecting rods in my mind doesn't necessarily solve the issue - is there a good way at all to diagnose where the pressure loss may be occurring other than tearing down completely? Also, how do you know it is not some other area such as top end lubrication that is the source of the problem?
For me, getting under the car and dropping the pan is okay for the pump and maybe the connect rods, but for messing with the crank mains I'm not sure I'd want to do it under the car.
Randy
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
S For Sale Triumph TR4 Factory Parts and Service Manuals on CD/ROM - 1961 - 1965 Triumph Classifieds 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
N For Sale 1964 Triumph TR4 street racer Triumph Classifieds 0
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
B Triumph TR4 replacement fuel tanks Restoration & Tools 3
T TR4/4A 1963 Triumph TR4 Triumph 11
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
V TR4/4A Triumph TR4 A clutch assembly and gearbox Triumph 6
Stinger TR4/4A 1967 Triumph TR4-A FOR SALE Triumph 9
Triumph_TR4_Girl TR4/4A Second Hand Copy of Original Triumph TR4 Triumph 1
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
CZ_Dave Triumph TR4 Spotted 0
J TR4/4A Triumph TR4 Body Restorer Chicago Area Triumph 3
Atomic8 TR4/4A 1965 Triumph TR4 For Sale - $17,875 Triumph 4
M TR4/4A SVRA NJMP Triumph TR4 in-car Triumph 3
Tabcon TR4/4A Triumph TR4 T3T4 Turbo Charger Kit Triumph 3
C Triumph TR4 racecar build [w/ detailed photos!] Racing 2
3798j TR4/4A A Golden Triumph TR4 Triumph 10
Cabrioman TR4/4A History of the Triumph TR4 and the Surrey Top Triumph 10
glemon TR4/4A Complete Original Triumph TR4-6 Triumph 10
SCguy TR4/4A TRIUMPH TR2 TR4 DOOR RESTRAINT ASSEMBLY Triumph 1
KVH TR4/4A Triumph TR4/4A--The Horn Triumph 2
Tim Tucker TR4/4A Book Review Request: "HOW TO RESTORE TRIUMPH TR4" Triumph 5
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
