How to connect a horn relay
Ray7Smith
I need some guidance on how to hook two horns to a horn relay. I just purchased a set of hornes and they came with a relay.The relay has five male prongs. The harness used to connect the horns has two wires, one is brown and black the other is brown and green. The hornes each have two male prongs. I can't figgure out how they are connected. Can someone give instructions.
Is it necessary to use the relay?
Ray
Dave Russell
Yoda - R.I.P
You don't really need the horn relay. Just connect the new horns as in this sketch of the original wiring.
richberman How to connect horn wiring 57 100/6 BN4 Austin Healey 2
S TR2/3/3A were the 2 metal gas lines connect Triumph 18
R engine removal- where to connect hoist? Austin Healey 16
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber And these Vents on the valve cover connect to? / Nice Heater hose Valve Spridgets 7
Jer Funny how cars can connect people... Spridgets 7
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
1 Why I can not connect the Bluetooth ELM327? Jaguar 1
M TR2/3/3A 56 TR3 What sould these two grounds connect to Triumph 9
RickB General Tech Need pictures showing how to connect choke on HIF carbs. MG 2
M t mobil smart phone unable to connect FORUM Navigation Questions 0
T Engine pulling question - where connect Triumph 10
R Connect electric fan to coil terminal Austin Healey 16
Steve1970 how does the heater control plinth connect? Triumph 4
H How Does Battery Cable Connect to Shut Off Switch? Austin Healey 21
G Where does my oil pressure line connect? Spridgets 4
P TR6 Horn issue 1974 TR6 Triumph 5
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
