And these Vents on the valve cover connect to? / Nice Heater hose Valve
Jim_Gruber
So the Valve Cover on my 948 has two vent / vacuum fittings on it. What are these fittings plumbed to. Rubber hose to oil chassis underneath?
Interesting Heater Valve fitting. I haven't seen one like this before. Too pretty to put a wrench on the big knob to free it up. Now to get it off and see if I can free it up so it open and closes. View attachment 43627View attachment 43626
Billm
The front fitting should go to your air cleaner but the back one was added and should be plugged or removed (or just get another rocker cover)
BillM
Jim_Gruber
Jim_Gruber
Cool that's what I thought.
59diamond
Or better yet just fly Bill M to Dayton on an all expense vacation or talk him into visiting his brother and i bet you will be up and running long before August 6th.
Jim_Gruber
Jim_Gruber
Yes that's another alternative but what challenge is there if I do that. I need have the to personal achievement and fulfillment and the problem solving fixes that I solved to feel emotionally involved with this BE. Come to think about it, I probably need to chat with a Therapist on that topic.
nomad
BillM
Well, I kinda like the hose dropping down to keep the chassis oiled idea!:encouragement:
Jim_Gruber
Jim_Gruber
I already have one hose hanging down there already I don't need two.
Will be curious to see if I have copious amounts of blow by or not. Supposed to be a rebuilt engine.
Compression test tomorrow. I'll pride complete results.
Patrick67BJ8 Hardtop Vents Austin Healey 10
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
HealeyPassion Works Rally Side Vents Austin Healey 24
Darwin Spitfire scuttle vents Triumph 0
M E-type series 1 plastic dash vents Jaguar 1
TulsaFred Proper attachment of Demister tubes and vents Spridgets 3
S General Tech fuel line vents in general Triumph 4
maxwedge5281 rally vents....again!! Austin Healey 6
maxwedge5281 aluminum fender vents installation Austin Healey 14
S Aluminum wing vents for BT7 3000 Austin Healey 1
B Does a 100 Six with no heater have demister vents? Austin Healey 5
Keith_M demister tubes and vents Spridgets 2
Flash_Harry MGB "Vents" on a new battery? MG 9
2billydavies TR2/3/3A gas pouring out of the carb vents Triumph 5
maxwedge5281 advice on rally vents Austin Healey 32
maxwedge5281 side vents Austin Healey 16
E TR4/4A TR4 Wooden Dash Facia vents Triumph 13
B AH 100 heater vents Austin Healey 0
B Side vents Austin Healey 4
J New SU Fuel Pump - Gas leaking out of carb vents Austin Healey 24
S big healey fender vents Austin Healey 11
K TR4/4A Fender vents on a TR4? Triumph 17
davidb Big Healey fender vents Austin Healey 23
AUSMHLY Works rally side vents...more than meets the eye Austin Healey 18
v8mgbal Side vents Spridgets 4
R 2500M Vents TVR 3
mountainman TR2/3/3A Tr3 Defroster Vents Triumph 8
HealeyPassion Works side vents project paper Austin Healey 13
DNK TR6 TR6 Vents Triumph 0
NutmegCT H6 carb - float vents Triumph 4
M electrical smoke from cowl vents Triumph 8
hondo402000 TR6 TR6 Eyeball vents Triumph 5
R Side vents Austin Healey 7
Lin Oil Cooler Vents Austin Healey 12
R fender vents Austin Healey 3
TomMull Valve lash Lotus 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
