Do I have a panhard rod problem?
John_Progess
I took the BJ8 Phase I out for it's first extended run Saturday and noticed that upon acceleration and deceleration the rear of the car had noticable side movement. I tightened up the U bolts and got the panhard rod nuts a couple of more turns. Is there something else I should be checking? Thanks and have a good day!
John
Are your tires inflated properly? How old are they?
Leaf springs are attached to the chassis front and rear both sides, diff is bolted tight to both spring sets minimal side movement :frown:
Tire pressure is 32 psi rear, 30 psi front. Tires are 165R15 and are michelin xzx but are 8 years old with about 10K miles on them! Plan is to replace them soon. I tried to last week but could not find any suitable tires. What tire size are most people using on their Healeys? My rims are 5.5" wide. I will take it out for another test run today. Thanks for your info and have a good day!
John
I have an early phase 1 (built Nov 63)and I just tightened the pan hard rod replacing the bushings. They seem to need replacing every 4 or 5 years. That keeps the rear left spring stable. I believe phase 2 (April 64 ?) were different. Check the front sway bar bushings as well.
As there isn't much that can go wrong with the rod, check its attachment to the leaf spring on the left side(two nuts and bolts).
:iagree:With all above. It's also important to make sure the leaf springs are properly installed. The bolt head on the lower portion of the leaf springs fit into a rectangular bracket with a suitable hole at the bottom. It's easy to verify by just looking at the springs with a light from behind. If you can see light through the spring the bolt isn't in the hole. While under there check that the drive shaft isn't loose.
John,
In my experience, if the rear end of the car has sideways movement one direction when accelerating and the other direction when decelerating it usually means the rear axle is "steering" the car. One side or the other is moving forward when accelerating and moving rearward when decelerating. This could be caused by several things; Loose u-bolts (which you tightened), broken or missing center bolt in the spring (this bolt holds all the leaves in their proper locations and also helps to locate the axle in relation to the spring, loose pins & bushings in the ends of the springs, a broken main leaf in the spring, or a broken/cracked front spring hanger/outrigger.
The panhard bar keeps the car body/chassis from shifting over the axle when cornering but has little to do with sideways movement when going straight, and should not be affected by accelerating or decelerating.
Hope this helps,
Dave
Make sure your splines are bolted down tight to the brake drums?, mine came loose one one side once and exhibited similar symptoms.
On my '67 MK3, the bushings were bad in the upper radius rods.Caused me to spin out one night after downshifting, ( might have been Quervo). Will really make the rear-end assembly walk under torque& acceleration, almost feels like your going to change lanes when you let up an then nail the throttle. Replaced bushings, no problems. cheers Genos2
Thanks for the response. The problem seemed to be considerable better after I tightened the u-bolts on the right side. I am going to re-tighten everything and go for another ride. The hubs, wheels, bushings are all new. Wheel bearings were fine. Thanks again and have a good day!
John
Healey Nut BT7 Panhard Rod Austin Healey 28
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
John Turney Panhard Rod Austin Healey 14
steveg Is a Panhard Rod Necessary? Austin Healey 34
Simmo TR2/3/3A Panhard Rod Triumph 9
N Panhard Rod Mounting???? Spridgets 9
K Panhard Rod on a TR3 Racing 3
H Panhard rod Austin Healey 1
aeronca65t Panhard Rod for Sprite Spridgets 0
DanLewis Panhard Bar Kit from Mini Mania Spridgets 0
DanLewis Would a Panhard bar fix this problem? Spridgets 11
Nelson Panhard Bar vs Watt's linkage Spridgets 17
K TR2/3/3A Panhard or Rear Sway Bar on aTR3? Triumph 10
Trevor Jessie Panhard Bar Spridgets 29
R Panhard Bar Kit Spridgets 3
T panhard bar for tr4-where to locate & mount Racing 20
T TR4/4A looking for pictures-tr4 with panhard bar Triumph 7
GB1 Panhard Mounts Spridgets 7
GB1 1/4 elliptical Panhard & Sway Bar Spridgets 1
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Walter74 Steering Rod Installation Austin Healey 6
red57 Rod Bearing Clearances Austin Healey 4
BoyRacer Odometer Reset Rod Austin Healey 4
K TR2/3/3A Removal of tie rod end? Triumph 7
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
R TR2/3/3A Throttle rod spring location Triumph 3
I Brake rod questions Spridgets 7
Y MK V rod bearings Jaguar 1
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R Connecting Rod Big End Specification Austin Healey 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
T TR6 Air vent rod connection Triumph 1
F TR2/3/3A Throttle linkage cross rod Triumph 4
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
