Panhard rod
higgins
One of these evenings where I've had nothing better to do then finally change the worn bushes on the panhard rod.
Quick and simple question:
How far do you tighten the rod? /bcforum/images/%%GRAEMLIN_URL%%/confused.gif
regards
Higgins
Dave Russell
Yoda - R.I.P
I don't believe it's too critical. Tighten until the donuts are compressed to 3/4 of their original thickness. (1/4 compression)
Healey Nut BT7 Panhard Rod Austin Healey 28
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
John Turney Panhard Rod Austin Healey 14
steveg Is a Panhard Rod Necessary? Austin Healey 34
Simmo TR2/3/3A Panhard Rod Triumph 9
N Panhard Rod Mounting???? Spridgets 9
K Panhard Rod on a TR3 Racing 3
J Do I have a panhard rod problem? Austin Healey 12
aeronca65t Panhard Rod for Sprite Spridgets 0
DanLewis Panhard Bar Kit from Mini Mania Spridgets 0
DanLewis Would a Panhard bar fix this problem? Spridgets 11
Nelson Panhard Bar vs Watt's linkage Spridgets 17
K TR2/3/3A Panhard or Rear Sway Bar on aTR3? Triumph 10
Trevor Jessie Panhard Bar Spridgets 29
R Panhard Bar Kit Spridgets 3
T panhard bar for tr4-where to locate & mount Racing 20
T TR4/4A looking for pictures-tr4 with panhard bar Triumph 7
GB1 Panhard Mounts Spridgets 7
GB1 1/4 elliptical Panhard & Sway Bar Spridgets 1
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Walter74 Steering Rod Installation Austin Healey 6
red57 Rod Bearing Clearances Austin Healey 4
BoyRacer Odometer Reset Rod Austin Healey 4
K TR2/3/3A Removal of tie rod end? Triumph 7
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
R TR2/3/3A Throttle rod spring location Triumph 3
I Brake rod questions Spridgets 7
Y MK V rod bearings Jaguar 1
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R Connecting Rod Big End Specification Austin Healey 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
T TR6 Air vent rod connection Triumph 1
F TR2/3/3A Throttle linkage cross rod Triumph 4
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
