TR6 VERY tight Tie Rod ends
Phil73
Member
A couple years back I ordered a pair of outer Tie Rod ends from TRF. Then I got distracted and didn't get around to installing them until this past weekend.
The problem I'm having (or more precisely might be having) is that the new tie rod ends are extremely stiff and I'm wondering if that's right or not. The ones I took out I'm able to move the ball joint with just my hand but...those tie rod ends are 25+ years old so...who knows. The new ones I can't move with my bare hands at all. If I put a nut on the threaded portion of the ball joint and (gently) clamp that in a vise I can move the ball joint by inserting an 18" rod in the threaded portion of the tie rod end but, without some sort of leverage like that, I still cannot budge the ball joint even when its clamped in a vise.
Has anyone else experienced this? Is it normal?
Poolboy (on another forum) has already said his were pretty tight but I'm looking for additional thoughts on whether these tie rod ends are defective before install them.
glemon
I am surprised they are that tight, a new part will usually feel a lot tighter than your well worn used piece, but needing that much leverage to move seems excessive. You could check with TRF and see if they think or if they will do a return or exchange. That said, assuming they are still sealed and lubricated it should work fine and loosen up with time. If the resistance is strong but smooth and steady maybe just tight, if resistance to movement is "scratchy or variable, moves easily a little ways, the hard a little ways, I would definitely not use them.
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
S TR6 Very nice original one-owner TR6 for sale in South Carolina Triumph 0
Bayless The very simple rotisserie Spridgets 3
G TR4/4A Flasher Unit...VERY hot Triumph 10
R Very Difficult cold weather starting problems! Austin Healey 21
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
F Check out this new restoration diary - BT7 - very brave! Austin Healey 7
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
drambuie The nasty boy Healey version may very well be more true to the original intent! Austin Healey 14
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
andrea Very strange austin healey 3.9 Austin Healey 5
P gearbox shifts very badly Austin Healey 7
T TR2/3/3A Air dam seems to be working very well Triumph 5
W Very respectable restoration Spridgets 9
RJS TR4/4A Clutch Fluid Very Dark After One Year Triumph 5
tinman58 TR5/TR250 Very stiff rear end Triumph 27
fpstude TR4/4A Another Wiper Question - Very Sluggish Triumph 12
bighealeysource Best way to remove very fine scratches in chrome windshield frame Restoration & Tools 2
bighealeysource Best way to remove very fine scratches in chrome windshield frame Austin Healey 1
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
drooartz MGB Sometimes I'm very proud of my work... MG 6
John Turney UPDATE: Up-date on a Very Expensive Healey Austin Healey 8
D BT7 Hard top back window that is very cloudy Austin Healey 5
NutmegCT Buying this will sure make someone *very* happy. Other Cars 14
B very excited! Just ordered my Ford Mustang 2013 GT Other Cars 1
pkmh HBJ8 Steering Wheel Repair Experiment - VERY GOOD. Austin Healey 7
tr7andtvr Very Disappointed with Lotus at Indy 500 Lotus 13
swift6 A very wild morning drive... Triumph 34
C One very cool Allard Other British Cars 2
C A very pretty little Elva MkVII Racing 1
RickB VERY OT - what I'm doing while on sick leave... Spridgets 10
JPSmit Very cool rat rod! Other Cars 3
C The Story of a Very Special Jaguar Racecar Jaguar 2
JPSmit Need a MOWOG and very confused Spridgets 13
C Very nice Triumph-Powered TVR 2200 Special Racing 9
J Anyone interested in very original 1958 Bugeye? Spridgets 1
RickB Needo to install a very loud horn - freeway 'fun' Spridgets 27
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
V Very nice Jensen Healey on eBay Other British Cars 10
14dna Very Sad Sight Spotted 0
T very early gear wear Triumph 8
JPSmit very scary engine noise Spridgets 37
