Panhard Rod for Sprite
aeronca65t
I was asked about my self-built panhard rod a while ago. These aren't great pictures, but maybe you'll get the idea. The bar (red pipe) was modeled after a "Peter May" unit. It's been working fine for around 3 years.
Below--Right side of the car from the rear:The bar was built out of ordinary plumbing-grade steel tube. I got rod ends from Summit Racing and threaded the bar so that a rod would thread into each side. I built a split aluminum block that clamped around the right side of the rear axle. The block has a mounting stud for the right side of the bar. The arrow is pointing to it. Even though the block is clamped tightly to the axle (and I used adhesive) it tended to "walk" radially around the axle. I made a "temporary" repair using a short length of chain that connects one of the clamp bolts to the leaf sping U-bolts. Eventually I'll do a more elegant repair...maybe. You can also see the right-side tube shock and the battery box in front of it.Takes about 90 minutes to change the battery, but it's nice and low for better CG. There's also a fuel pump near the battery (normal 1500 cars have a mech. pump). The fuel cell is 8 gallon ATL.
Below--Left side of car from the rear: The yellow arrow is pointing to the pivot bolt for the left side of the panhard rod. The tripod (red tubes) that holds the left side of the bar to the frame is built form steel tube and angle-steel. When the car is at rest on the ground (not jacked up) the panhard rod should be about parallel to the rear axle from the rear view and the top view. The longer the panhard rod (within practical limits) the better. I had a 5/8" sway bar on the rear at one point, but it made the car handle creepy, so I pulled it back off (none of the other Sprites I race have a rear sway bar). Tires are Yoko A032R soft-compound/shaved. I have two extra leaf springs added and spacer blocks between the axle and leaf-spring to lower the car.
Healey Nut BT7 Panhard Rod Austin Healey 28
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
John Turney Panhard Rod Austin Healey 14
steveg Is a Panhard Rod Necessary? Austin Healey 34
Simmo TR2/3/3A Panhard Rod Triumph 9
N Panhard Rod Mounting???? Spridgets 9
K Panhard Rod on a TR3 Racing 3
J Do I have a panhard rod problem? Austin Healey 12
H Panhard rod Austin Healey 1
DanLewis Panhard Bar Kit from Mini Mania Spridgets 0
DanLewis Would a Panhard bar fix this problem? Spridgets 11
Nelson Panhard Bar vs Watt's linkage Spridgets 17
K TR2/3/3A Panhard or Rear Sway Bar on aTR3? Triumph 10
Trevor Jessie Panhard Bar Spridgets 29
R Panhard Bar Kit Spridgets 3
T panhard bar for tr4-where to locate & mount Racing 20
T TR4/4A looking for pictures-tr4 with panhard bar Triumph 7
GB1 Panhard Mounts Spridgets 7
GB1 1/4 elliptical Panhard & Sway Bar Spridgets 1
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Walter74 Steering Rod Installation Austin Healey 6
red57 Rod Bearing Clearances Austin Healey 4
BoyRacer Odometer Reset Rod Austin Healey 4
K TR2/3/3A Removal of tie rod end? Triumph 7
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
R TR2/3/3A Throttle rod spring location Triumph 3
I Brake rod questions Spridgets 7
Y MK V rod bearings Jaguar 1
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R Connecting Rod Big End Specification Austin Healey 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
T TR6 Air vent rod connection Triumph 1
F TR2/3/3A Throttle linkage cross rod Triumph 4
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
