This will be a fairly obscure question but it never hurts to ask. My car is a mongrel, a '62 BT7 with a '66 BJ8 engine. It looks pretty good and runs well; my non-concours "restoration" is going slow but steady. One thing I'd like to do is make it externally close to accurate. Here's the issue: The current gauges are black-faced off a BJ8 fitted into a BT7 dash. They look good and function well. I'm restoring the dash to match the red interior (the dash currently is black) and have a set of BT7 gauges. Gold faces and, I now realize, significantly different wiring than the BJ8 gauges, at least for the tach. I've seen where BCS offers sets of gauge faces. Just eyeballing the two types of gauges I suspect I cannot use a set of older faces on my BJ8 gauges (e.g. the needles are sort of elevated on the older guages, the BJ8 gauges are pretty flat, etc.) Has anyone tried this? Can you swap older gauge faces onto newer gauges? Many thanks,
-Tom
-Tom
