    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Brake union Switch Triple Master HELP!!!!
blkcorvair
Okay, so my master cyl is leaking which is fine by me. Just a good excuse to set the car up for a triple master setup with adjustable bias. Got all the parts on the way via Santa Claus including a 10lb rp valve for the rear. Heres my question, I am exploring the various fittings I will need to purchase.
This warning swith block. Does anyone know if this serves any other purpose? Will it have any negative effect on the brake bias system, ie; does this also serve as a poportioning valve of sorts or is this simply a splitter with a warning switch?
My reason for asking is obviously this is in a hard to reach location now that everything is installed. Just need to know if it should come out or if its fine to leave in with the seperate master cyl.
aeronca65t
All it does is sense a difference in pressure from front and rear brake systems (to activate a warning light). Nothing else.
You can delete it.
My Spridget still has one, but if I put in new lines, it's going.
I'm looking at creating a new hanging pedal system for my A-35 (it has floor mounted pedals) and I've been looking at the Tilton bias setup. Expensive!
B
blkcorvair
I went with the wilwood setup. (Very similar.) but the pedals were slightly shorter than the tilton. I'd like to leave that pressure switch in if possible just cause all the lines are already new and I'd have a real tough time squeezing a flare tool in that spot to redo the one break line that runs over to the pass side. I'd have to get a tee of sorts to replace it anyway, so if it dont hurt nothing it'll stay. Ill shoot you some pics of the wilwood setup after its all mocked up.
aeronca65t
Yeah, if you've got new lines, leave it in. It won't hurt anything.
I'm going to snoop around the local junkyard and see if I can find a set of pedals in a modern car that'll work. Probably just use a regular dual-master cylinder...no bias bar.
Here's one I built a few years ago, the key is to level out the cylinder, if you mount them to the original footbox everyhting sets at angle, including the fluid in the cylinders. Under the aluminum tinwork is a mounting structure for the pedal assembly, made form small square tube and flat bar. On the next one i buiild i've ben thinking about going with .125" aluminum and building structure for the pedal assembly to bolt to and the whole deal bolt to the footbox, so if i ever need to remove it, i could fairly easily, also make removeable acess panel on the side of the footboxes for working acess thaere, since my front ends are always ame to be removeable. Just thinking outloud :smile:
B
blkcorvair
thanks for the pic hap. i seen an old post you made of something simialr or maybe it was this in its raw state. Ive got an idea in my head ofthe layout. Hust need all the bits to see what lines up where.
glemon TR5/TR250 Restoration Pics needed Brake Pipe Union TR250 Triumph 2
I bugeye brake union thread size? Spridgets 2
B TR2/3/3A Advice needed - cleaning TR3 brake pipe union Triumph 11
jmwuva05 I need a four way brake union bad!!! Spridgets 4
jmwuva05 4 way brake union Spridgets 0
jmwuva05 Front drum brake union pipe Spridgets 4
M Brake Servo Austin Healey 8
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 8
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
