Brake flaring tool
drooartz
I've got to do some work on the Morris' brake lines, and need to do all the lines for the Bugeye. Time to get a brake flaring tool!
Gerard recommended one from Rigid. I was wondering if there were any other recommendations out there.
TR3driver
Great Pumpkin - R.I.P
Almost doesn't matter if you use Cunifer line; it flares easily. OTOH I once made the mistake of buying some pre-flared steel line at FLAPS, and that stuff was nearly impossible to flare successfully. I tried several different tools, finally managed to get a barely acceptable flare using a Snap-On tool kit borrowed from a local garage. Still not pretty, but good enough.
twas_brillig
I was just looking at the Fedhill brake line etc. site, and they'll sell your or rent you a 12 pound flaring tool. "$25.00 for the first two weekends,(time in shipping not counted) then $25.00 per week after that, plus $375.00 security deposit. $400.00 will be charged to your credit card. " Doug
BlueMax
What else is needed other than a double and a bubble flare on British cars (Bugeye Sprite)? Hummm, curious minds want to know?
TR3driver
BlueMax
Don't know how or why you had issues, but mine went smooth as silk.
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
jaegzie brake flaring tool Restoration & Tools 5
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
D TR6 TR6 Brake Line Flaring Triumph 6
M brake servo Austin Healey 3
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
