1275 Race Clutch
MJinCO
New to vintage racing with 1275 Midget. Motor 11:1 CR, 45DCOE, Header,296 scattercam. I blew up the clutch which was a stock Borg and Beck, so I'm clutch hunting. I am not going to go Tilton at this point, only other race type I have found is a Stage 4 Spec. Spec can also do a stage 2 which is the stage 1 with a better lining of kevlar. Minimania has a performance clutch but no idea of what makes it better. Looking for suggestions as to what to get.
M
MJinCO
I bought a stage 2 Spec clutch. I couldn't find even a AP available and I fear a aftermarket stock replacement would not be as strong as stock. I'm not sure I'm up to handling a real race clutch at this point so I passed on the staege4 Spec.
jfarris
Local company with a great reputation for reliable products. I put one of their clutches in my 2001 Boxster S, smooth as silk. I hope it works for you.
Jerry
Look at the options on Mini Spares in England also. They have a lot of choices and supply parts to minimania
M
MJinCO
Got everything back together. Found that a PO had ported the intakes into the pushrod hole and the filled the hole with epoxy/JB Weld, looks like some sleeves will be need for that. Fortunately I have 2 extra 12G940 raw heads, one is a later pollution control one. Having an issue with tranny mount, have all the bolts in except the bottom ones. The only long bolts I have left are about 3" long 3/8NF and they won't start so I guess my next move is to take out the side mount bolts and to let the assembly float around a bit to try to get the bottom ones in. A 5/16 NC felt like it wanted to start. Suggestions?
Found it much easier to get the assembly back in than I expected. I could get the drive shaft lined up well thru the shifter hole then jacking up the tranny a bit to improve the alignment. The LSD made the driveshaft turn easily and it slipped right on. The Speedwell solid motor mounts took a bit to get lined up, but much easier than a stock one unless the base is slotted.
dougie
MJinCo -
This site has more true racers & tuners that can help with all your race questions in the future....
aeronca65t Clutch pedal problem- 1275 race car Spridgets 12
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Rut How much does a 1275 weigh? Spridgets 8
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
