1275 Exhaust Manifold Needed - Along with Advice
mxp01
Gentlemen:
I was attenhing the exhaust to the exhaust manifold yesterday when it broke. There was a collar on the manifold that I connected to a collar on the exhaust. I ran two bolts un from the lower collar and connected them to the upper collar. I must have overtightened the bolts and the upper collar snapped loose from the manfold.
Here are my questions:
- Can this be repaired?
- I looked at exhaust manifolds for 1275s on Ebay. Most have studs that come out the manifold. Mine doesn't look like that at all. Can anyone recommend the 'right' one for my car?
- Does anyone have one they are willing to sell?
Let me know,
Mike Pennell
In 1968, the exhaust pipe and exhaust manifold changed from the earlier "muffler clamp" type design with two bolts, to the flange type with three bolts and a "real" donut gasket. I had a 1959 BE years ago, with the 948. I was always having exhaust leaks. I'm not sure if I had the steady support to the transmission or not, which is absolutely required.
So when I built up my 1960 BE with the 1275, I used the header, exhaust pipe, and muffler from the '68. So far so good, as it is a much better design.
The only downside, is that the exhaust pipe exits from under the car on the right side of the left bumper, where on the BE it is on the left. I may have an 1275 exhaust manifold if you need it.
Scott in CA
Scott
If you had put the 1275 exhaust from a '69 on there then the muffler would exit in the correct location.
BillM
Okay, let me ask this:
Will the 948 exhaust manifold (I have a spare one) work on the 1275 engine with the 948 exhaust pipe (which I have in the car)?
Please let me know,
Mike Pennell
yes will work but actually the diameter of the exhaust is different. 948 is smaller of course and 1275 larger.
A 1275 exhaust on a 948 will give you 2 to 3 more HP.
M 1275 Exhaust Manifold Needed Spridgets 6
TulsaFred 1275 exhaust manifold ? Spridgets 1
B 1275 exhaust on MKI Midget [1098] Spridgets 3
healeyboz 1275 Header and exhaust Spridgets 25
S exhaust 1275 MG 3
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
