1275 build
Rut
Please don't give me any undue grief over this! The machine shop that did all my machine work on both MGB engines and on my 1275 also builds engines and they come with a 100,000 mile warranty backed by Federal Mogul. That said I called my guy and asked him to assemble my 1275 since I'm consumed by Bugeye assembly and I'm getting farther and farther behind. I have about 2-3 days every 2 weeks to devote to my Bugeye since SWMBO has decided we need to travel while we can and spend time at the beach.
i have everything that I ordered from Hap and most of the stuff is owned by Federal Mogul now, so I may get a warranty out of this, but no holding of breath! Ok, here's what cinched it for me...$125 to assemble the short block or $300 for everything and this is the best friend deal. He also came to my house to install both MGB engines and do anything else I couldn't do as well as reviewing my work.
Rut
SaxMan
Sounds like a great deal to me. Wish I was closer to your shop when it comes time to rebuild Baby Blue's 1275.
Rut
Rut
Just to clarify...all the machine work had been done previously and this is only assembly.
Rut
dklawson
$125? That is nothing. Think how much you pay a technician to plug in the OBD2 reader when they "fix" your modern car. You got a great deal !
drooartz
Sounds like a great deal!
There's no shame in farming out work when you are out of time. There are only so many hours, and sometimes you just need more hands on the task then you have. Good luck with it, and you'll be driving that Bugeye that much sooner!
Rut
Rut
Drew,
Im lucky to have such a talented friend and he would probably do it for free if I let him, BUT I've assembled every part of this car besides the paint. I love to tinker and this car and forum have taught me so much I'll be ready to tackle everything on the TR4a. I thought about farming the engine work out for quite some time before I made the call yesterday and the 'I did that' factor looms large. Yes, I'm the guy that the home repair people talk about when they say 'we'll repair what your husband fixed'.
Rut
Rut
Rut
This sentence from my Nasty Boy build page always rings true:
"Lots of progress, mostly because I paid someone else to do most of the work."
"Sometimes the best tool in the toolbox is a credit card". I understand the logic and can accept the fact that I can't do everything before I get TOO old!
Rut
Rut 1275 build Spridgets 2
Rut 1275 build Spridgets 12
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
