Wheel spacers
PeterK
Where can I find direct-fit wheel spacers for a TR4-6. All I seem to find is the universal type with slotted holes and my KN wheels are lug-centric not hub-centeric so a universal spacer doesn't center on the lugs without a lot of slop? I thought of buying a chunk of aluminum and having it milled but would be easier to find them pre-made. Bolt circle is 4 x 4.5 (114.3). I need 5/16(8mm) and 1/8(3mm) thickness. Any help? Thanks. PeterK
Alan_Myers
Hi Peter,
Your best bet for spacers specifically made to fit TRs is the major British vendors. Check with www.revingtontr.com, www.cambridgemotorsport.com and https://www.racetorations.co.uk/
I know Neil Revington makes spaces specifically to allow centerlock wheels to be mounted without cutting shortening the standard lug nuts, to make it easier to swap back to bolt-on wheels. But, I seem to recall theses are 11mm thick.
Hope this helps.
Alan
Rick O.
Peter--Several spacers have popped up on ebaY the last few weeks; check there.
PeterK
PeterK
What I'm looking for is a 6" diameter washer with holes drilled specifically for a 4 x 4.5" bolt circle, no slots or universal fit (like ebay or Moss have) and not for a splined hub conversion, just to space my KN Minilites away from the suspension. Somebody has to have them.
If anyone has the KN Minilites, have you have fitment problems? My front wheels hit the top a-arms and the rear tire rubs on the leaf spring (barely). Backspacing is 4", wheels are 15 x 5.5.
Alan_Myers
Hi Peter,
I have 6" wide Panasports on my TR4 that run pretty close to the upper A-arms when the steering is turned to full lock. It's only about 1/4 or 3/8" from the wheel rim.
This is due in part to the wider wheels and also by installing a custom top bracket that dials in some negative camber (which I got from Revington TR).
I had even less clearance before I used a grinder to reshape the upper end of the front A-arms, so that it tapers more gradually to a point. This is a common modification when running wider wheels.
The other modification I made was using a half-height Nylock nut at the point. It wasn't rubbing, but was pretty close.
Now there seems to be enough clearance, however if I need to, I can always put a larger diameter steering stop to keep the wheels further from the A-arm, although that will reduce the turning radius slightly.
I haven't installed the rear end yet or had the car on the road. Spacers might be the only possible solution for the rub on the leaf spring and you might be best ordering them from England. I've bought from Revington and Cambridge, and will again.
After fitting the spacers, you may want to check for rub on the inside of the fenders.
Let us know how it works out.
Alan
mightymg
Member
I know there is a set of spacers on Ebay right now with 4 days left on it. Check it out. /ubbthreads/images/graemlins/patriot.gif
PeterK
PeterK
Alan,
Thanks for the tips. I already cut the point off the front upper a-arms and am using a 1/8"(3mm) spacer for clearance. I used double sided photo mounting tape to center the spacers to the hub while I installed the wheels. I checked Revington, Cambridge, and Racestorations and they all carry universal (i.e 95-114.5 multifit) spacers, same as Moss and common on ebay, and same as I already have. I think that I'll have to make a set myself with the proper 7/6" hole 4.5" bolt circle. The trouble with universals is that your wheels won't balance if the spacer is not held concentric to the hub. Thanks!
Paul Johnson
OK, but understand that by moving the wheels out, you're changing the weight of the car more onto the smaller, outer wheel bearings, and this will, in time, have an impact.
PeterK
PeterK
Paul,
I need to move the wheels out 5/16" - on a disc wheel car the track is already 1/2" narrower on each side (because of the hub convertors on a wire wheel car) so I am effectively moving the wheels inwards 3/16" each from a wire wheel car which shares the same bearings. We're not talking rice racerboy with dinky tires sticking out a foot! /ubbthreads/images/graemlins/driving.gif
Paul Johnson
Peter - you're correct. My thought was to point out consequences to anyone who might not realize. No attack intended.
PeterK
PeterK
None taken. You're right Paul. BTW, to resolve my centering issue I ordered longer shank lug nuts that will inset into the larger holes of the wheel spacers I already have. The .679" diameter shank is still a bit smaller than the hole in the spacer but much larger than the 7/16" stud to keep the spacer from slippng sideways and just .20 longer so my .3125 (5/16") thick spacers will prevent them from bottoming (and as an added benefit, I get more usuable lug threads. Confusing to write but simple in hand. Thanks to everyone. Peter
zoohow wheel spacers Racing 1
F TR6 Wheel spacers Triumph 5
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
R TR4/4A Tr4a, wheel spacers and balance Triumph 5
R 5mm wheel spacers on front when switching Minilite Triumph 2
T TR2/3/3A wheel spacers for TR3 Triumph 13
B 1/2" Midget wheel spacers Racing 2
B Midget Wheel Spacers Racing 15
CraigLandrum Wheel Spacers? Triumph 11
W TR2/3/3A Correct thickness for wire wheel spacers [3A]? Triumph 13
Bret Shark got new rear wheel spacers Other Cars 15
Webb Sledge Wheel Spacers Other Cars 6
T TR6 Steering Wheel Lock Triumph 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
D Removing the steering wheel hub Spridgets 12
Todd78d Wire wheel cleaner Spridgets 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K 1068 mkIII wire wheel rub Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
K TR6 TR 6 Wheel Studs Triumph 10
AUSMHLY Front Wheel Spin Drag Austin Healey 6
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
Editor_Reid Wrapped Steering Wheel Austin Healey 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
kodpkd Leather Steering Wheel Cover Austin Healey 3
KVH General Tech Wheel Dollies Triumph 5
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
P 100/6 Front Wheel Alignment Austin Healey 10
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
prb51 BN6 Wheel/Tire Combo Austin Healey 26
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
LAW75 Derrington Steering Wheel Austin Healey 19
C Spitfire rear wheel bearing Triumph 2
