What gauge is this?.....added picture.
chuck1006
My 100-6 came with an incorrect oil/water gauge which I just replaced. The one that came with it is a JAEGER. The oil readings are from 0 - 100 and the water from 30 - 100 degrees C. It appears to work fine and I will probably sell it on ebay. Any ideas what vehicle it is for so I can list it correctly? /ubbthreads/images/graemlins/confused.gif
Thanks
Re: What gauge is this?
[ QUOTE ]
Pictures?
[/ QUOTE ]
Basil, my digital camera is out of commission now. I may borrow my son's this weekend to get some pictures.
If it only goes to 100C it definitely is not for a Healey.
Hi Chuck,
are you going to offer it to us BCF members before you put it on ebay?
mark
[ QUOTE ]
Hi Chuck,
Hi Mark,
Yes, I will if I can determine a fair price which I am not sure how to do right now. I will try to put pictures on this weekend.
Chuck
mark
[/ QUOTE ]
Most likely, Euro spec MGA or early MGB.
I had a Sprite imported from Spain with a Smiths 0-100C water temp gauge.
Finally got a new camera. Here is a picture with the glass off. Anybody know what it goes to or fair value? If no interest I will list on Ebay.
Thanks
curdy General Tech Gauge Dust Reduction Triumph 4
J For Sale Gauge brackets (lot of 7) for sale Other British Classifieds 0
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
G MGB ugh.....the fuel gauge went to *** again! MG 8
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
roscoe Fuel Gauge Austin Healey 0
G Smith's temp gauge repair Restoration & Tools 4
CARSINC eBay Gauge Packages Spridgets 6
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
Gatheringtree TR2/3/3A Gauge Set Triumph 17
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
LD-Ordie TR2/3/3A TR3 gauge service Triumph 11
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
B For Sale BaulyCars - Gauge Bezels Triumph Classifieds 0
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
BierRunner TR6 Temperature Gauge Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
Lairhead52 Wanted Oil Press Gauge Triumph Classifieds 0
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Fanch00 Inoperative Fuel Gauge Austin Healey 10
R Coolant temperature gauge Spridgets 8
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
Editor_Reid Water Temp Gauge Austin Healey 5
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
E Gauge Lights Austin Healey 4
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
R TR2/3/3A Fuel Gauge Triumph 19
nichola TR6 Smiths volt gauge needle barely moves Triumph 25
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
