For Sale BaulyCars - Gauge Bezels
BaulyCars
Hello Everyone,
I’m excited to introduce our custom designed Gauge Bezels for the TR6 Smiths gauges.
With a specifically shaped profile on their underside, the bezels form a matching fit over the Smiths gauge shape, fitting both early and late Smiths gauge types.
> Gauge Bezels - BaulyCars <
We hope you like them!
Many Thanks!
www.BaulyCars.com
B For Sale BaulyCars - Centre Caps Triumph Classifieds 2
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
curdy General Tech Gauge Dust Reduction Triumph 4
J For Sale Gauge brackets (lot of 7) for sale Other British Classifieds 0
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
G MGB ugh.....the fuel gauge went to *** again! MG 8
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
roscoe Fuel Gauge Austin Healey 0
G Smith's temp gauge repair Restoration & Tools 4
CARSINC eBay Gauge Packages Spridgets 6
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
Gatheringtree TR2/3/3A Gauge Set Triumph 17
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
LD-Ordie TR2/3/3A TR3 gauge service Triumph 11
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
BierRunner TR6 Temperature Gauge Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
Lairhead52 Wanted Oil Press Gauge Triumph Classifieds 0
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Fanch00 Inoperative Fuel Gauge Austin Healey 10
R Coolant temperature gauge Spridgets 8
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
Editor_Reid Water Temp Gauge Austin Healey 5
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
E Gauge Lights Austin Healey 4
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
R TR2/3/3A Fuel Gauge Triumph 19
nichola TR6 Smiths volt gauge needle barely moves Triumph 25
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
C MGA Fuel gauge question MG 8
