    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Weber conversion
aroostok
Am considering converting dual HS4 carb setup to Weber. Any ideas, suggestions. If recommended, what carb should I opt for. Will be used for street driving on a daily basis.
Stewart
If the su's are giving you trouble send them out to hap or another one of the good su rebuilders. Much cheaper than switching over to a new carb. Don't get me wrong I love my 38 outlaw on my B but if it originaly came with su's I would of kept them on.
ccougill
yep, the weber is only an improvement over the zenith stromberg, and Tony will argue that with me
100DashSix
I switched from HIF-4s that badly needed a rebuild to a Weber 32/36 DGV, as I found out it was cheaper and quicker to buy the Weber than it was to send the HIFs out to get them professionally rebuilt.
HOWEVER, I'm switching back to the SUs.
The Weber does perform decently (better than vacuum-leaking SUs), and gets pretty good gas mileage. But I feel like properly rebuilt SUs will give me better performance...plus they're original.
I heard that the Weber was more reliable, and I was planning on using my MG as a daily driver. Yet I rebuilt and tuned the SU carburetors on my Healey and haven't needed to touch them with a wrench for two years.
What I now plan to do is just have someone rebush the SUs for considerably less than an over-the-top rebuild, then complete it myself.
Hope this helps.
1965_MGB
Just my opinion, but I would stick with the SU units. I ran the same set for years, with leaking shafts and other issues, and I finally broke down and I am having a set done for my by Jimmy Hilton. I would have had Hap do it, but he is backed up with work right now. I am not sure if Jimmy posts here, but I know he is on one of the other MG boards.
PAUL161
If it costs around 600 bucks for a new Weber set up, I have one on the shelf, and it costs 360 bucks to have the SUs rebuilt like new, I had that done by Hap, then how do you figure your saving money by buying a Weber? If you have a late model single carb setup, then maybe a Weber will help, I don't know, but to throw away a pair of SUs and opt for a Weber is not the answer. SU carbs are almost bullet proof. The problem with them is, most people don't understand them. Notice I said earlier, I have a 32/36 set up on the shelf that I see every day. It's in plain sight, reason, to remind me not to waist my money again on a supposidly quick fix. JMHO. PJ
100DashSix
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If it costs around 600 bucks for a new Weber set up, I have one on the shelf, and it costs 360 bucks to have the SUs rebuilt like new, I had that done by Hap, then how do you figure your saving money by buying a Weber?[/QUOTE]
I bought a new Weber kit for $336 (which is still the price I find), and was able to finish bolting it on probably a few days after I got it. I don't remember who I called to have my SUs rebuilt, but the cost I was quoted wasn't $360..more like $500.
Platinum
My two pea:
SU's ~ARE~ bulletproof. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif Set 'em an' ferget 'em.
Only Weber conversion for a B is a DCOE mod, and that only if the engine has the mod's to make it an advantage. The down-draught conversion is a waste of resources, as Paul well knows.
Just lookin' at the two setups it should be noticed the DGV manifold has a 90* KINK in it right from the point of entry. SU's go straight to the valves. Small enuff arms and you'd be able to tickle th' intakes from outside. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
The illusion of "more power" with a DGV-ish thingie is simply because it has a squirter circuit, IMO.
EDIT: I'll do 'em (SU's) all day for $500 a set!!
ronzet
aroostok,
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif
IMHO, A properly adjusted pair of SUs are a joy to own. As was said earlier, set'um and forget'um...
I have had several As and Bs and have found the venerable SUs to be the easiest and cleanest choice. The Law of diminishing returns kicks in here... /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Platinum
meh... "What's WRONG with this *&^%#$ WEBER setup?!?!?! Can't make th' stoopid thing run at ALL!!!"
ronzet
DrEntropy,
I hope that is a rhetorical question... /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Platinum
I'm nothing if not rhetorical, Ron. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
...do you think it may be th' timing? /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
ronzet
DrEntropy,
Ahhh, yes the timing might be the problem, as in how much TIME it will take to put a set of SUs on it.. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Platinum
But... but all th' REALLY kewl guys say Webers is th' way t' go! I wanna have this car onna road so's I can show off at th' next gathering!
HELP!
...or words to that effect. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
DISCLAIMER:
This is in NO WAY a slam on anyone for wanting to go to a Weber conversion! That photo was as a complete farce for entertainment alone. The thing runs beastly strong with that DCOE and a Crane cam. Ported, matched, CC'd: the lot. I LOVE my side draught Webers.
Platinum
If I could figger a way to shove diesel fuel thru 'em then ALL the cars in the pile in my .sigfile would be Weber'd. /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
ronzet
DrEntropy,
You're such a kidder!! /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Now, aren't you slighting those of us who love the SU??? /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Wait a minute, if I use the word LOVE when discussing a carb configuration ---
I need to get a life /bcforum/images/%%GRAEMLIN_URL%%/rolleyes.gif
Platinum
Thought that happened the day you signed up for th' BCF?!?!
ronzet
DrEntropy,
Life is just an interruption to our passion for these D*#! Little British Cars.... /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
Coyote1 TR6 Weber 45 MCHH conversion for TR6 Triumph 15
J WEBER conversion on my BT7 Austin Healey 26
D DUAL WEBER 45 MCHH TRIUMPH CONVERSION KIT Triumph 2
rjc157 weber conversion kit Triumph 2
B TR6 TR6 Weber 45 MCHH Conversion Kit Triumph 10
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
A Wedge Can you tell me about this TR7 Weber conversion? Triumph 3
Y Weber carb conversion, Midget 1500 Spridgets 21
tosoutherncars 1500 carb conversion to Weber DGV Spridgets 14
C Weber carb conversion AH 3000 Austin Healey 3
S T-Series weber conversion on a spitfire MG 2
A Weber Conversion Triumph 27
7 Weber Conversion Q's??? MG 12
J Weber conversion Triumph 11
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
R For Sale Weber Primary Venturi (28mm) for 40 DCOE Triumph Classifieds 0
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
S Weber carb set Other British Cars 7
TomMull Wanted Weber 40 DCOE 18 Other British Classifieds 1
TomMull Weber Carburetors Lotus 18
C MGB More Weber help needed MG 27
C MGB Which Weber DGV is the right one. MG 14
R Weber DGV Advice Requested… TVR 19
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
A Spitfire Weber Carburetor Triumph 0
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
J For Sale Two used WEBER DGV 32/36 carbs for Triumph TR 2,3,4 Triumph Classifieds 0
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
steveg Weber balancer on HD8s Austin Healey 11
H General Tech Tripple Weber Swan Neck Manifolds for Triumph? Triumph 1
G Triple Weber DCNFs on 280i V6? TVR 1
P For Sale Weber carb/intake, header Spridgets Classified 2
H Triple Weber 45's Tipp? Austin Healey 2
JFS TR2/3/3A Weber Air Filters Triumph 7
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
richie TR4/4A TR3/TR4 Weber DCOE serious fitment issues Triumph 12
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
toysrrus TR6 Weber DCO45 cost? Triumph 6
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
bugedd Weber intake manifold Spridgets 4
T Understanding Weber DCOE identifiers? Spridgets 0
