VIN Plate stamping
David_Doan
What is the proper tool to put AN5L / 26655 on my new plate?
These - https://www.harborfreight.com/36-piece-18-steel-letternumber-stamping-set-60670.html
smaceng
VIN plateb.jpgI had a trophy shop engrave my old BE, but originally it was stamped at the factory. As you can see, my letter size was larger than the original. The HF says 1/8" .....measure your existing one and see if that works.
Scott in CA
Jim_Gruber
Clarke Spares will stamp it for you with the correct dies in the current size. Googke Ckarke Spares. They will also do door plates for VIN and body number.
I'd take a shot at restoring the original. Nothing to lose.
David_Doan
View attachment 34046I had a trophy shop engrave my old BE, but originally it was stamped at the factory. As you can see, my letter size was larger than the original. The HF says 1/8" .....measure your existing one and see if that works.
Scott in CA
I did a little more searching and measuring. Looks like the original is closer to 5/32". Trophy shop sounds like a good idea.
jlaird
Yes was going to say originals were stamped from back.
macsprite
Harbour freight tools has stamp sets that are the correct size. I stamped a new plate for my recent bugeye restore and it looked "original".
Cheers
Lew
Whitephrog
I'm with Jim....Clarke Spares did a prefect job on my VIN and engine plates.
Jim_Gruber
Get them to supply door tags for VIN and chassis number as well while you are at it as they have those as well.
sqbsprite
I would much rather restore the original. Spray it with black paint. The lettering is raised and you can polish it by rubbing it face down on 1200 grit sand paper until the border and lettering is clean and bright. The new plates are just screen printed and flat.
Jim_Gruber
Unfortunately Mr. Clarke passed away sometime after my original post in 2014. He was a Corvair Specialist IIRC. Unknown if anyone bought the business.
J New stamping for the vin plate Triumph 10
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
B Austin Healey 100/6 vin plate and serial number question Austin Healey 3
C What should the VIN plate look like for a BN1? Austin Healey 1
mgedit VIN Mystery - California Black Plate Triumph 8
TulsaFred How is the VIN plate attached? Spridgets 7
D MGB MGB VIN plate MG 2
Z AH BN1 Plastic VIN Plate Austin Healey 10
tony barnhill Need Photo of early VIN Plate Spridgets 19
emann VIN Plate engraving Spridgets 11
R TR6 Triumph vin tag information Triumph 7
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T VIN Number Austin Healey 2
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Year and Vin number Spridgets 5
B VIN confusion Spridgets 6
G TR4/4A Vin # for TR4A Triumph 3
S TR2/3/3A Vin TS for the car. Triumph 33
K MGA 1960 MGA Vin MG 3
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
JPSmit Midget VIN question Spridgets 1
Bob Claffie Vin/SN Spridgets 4
H Help decoding Sprite’s VIN please Austin Healey 6
Patrick67BJ8 Early 3000 vs BJ8 vin Austin Healey 3
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
69MGC MGC VIN Verification in California MG 4
B TR6 Title with correct VIN Triumph 8
Bantamfan midget vin Spridgets 4
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
Marvin Gruber BT7 vin plates Austin Healey 4
M TR2/3/3A 2nd commission [vin] number??? Help. Triumph 12
A Vin number question Austin Healey 14
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
Steve P. Need Bugeye vin tag & title Spridgets 15
pbraun Door pillar number used as VIN on title. What to do? Spridgets 11
pbraun Help with vin decoding Spridgets 18
bugedd VIN Question Spridgets 19
F TR2/3/3A vin # Triumph 6
B BN7 with BT7 VIN on eBay Austin Healey 11
madhouse 1958 100-6 VIN check [BT7 vs BN4] Austin Healey 7
M 1960 AH 3000, VIN help ? Austin Healey 4
M VIN Number Curiousity - 1960 MKI Austin Healey 1
Jim_Gruber VIN where else to look for #'s on a BE Spridgets 6
Jim_Gruber VIN number alternate locations - Somewhere by front suspension????? Spridgets 20
Rut Vin number Spridgets 3
bugedd VIN tag wanted Spridgets 20
R BN7/BN8 VIN search Austin Healey 9
R Healey VIN numbers Austin Healey 2
CJD E in VIN Triumph 10
PAUL161 MGB MGB vin numbers verses years. MG 6
