TR2/3/3A 2nd commission [vin] number??? Help.
Momikey
Hello,
I tried to register my tr3a that i got from Illinois at the aaa office in California and they said they need to see both vin numbers? The only one I knew about was right there on the plate under hood but we looked all over and did not find what they call the 2nd vin number. Does anybody know where this is on my tr3a? If I can't find it I have to fill out three sheets of paperwork and take it to the dmv.
Help.
TR3driver
Great Pumpkin - R.I.P
Doesn't exist and was not a requirement when the car was new.
You might try explaining that to them, but my guess is you'll have to do the forms.
charleyf
I once had a California Highway Patrol officer spend some time convincing himself of that same fact. The only thing he could come up with was the numbers on the front crosspiece of the frame. And those few numbers were meaningless.
Charley
Andrew Mace
Whatever you do, don't even MENTION any numbers other than the one on the commission number plate that should read something like TS12345L. Unless that doesn't match the number on your paperwork, in which case I suggest moving to a state that doesn't care. ;)
groupdeville
With only one VIN number, I believe the procedure is that California assigns a new number and will happily deface your car with an ugly new VIN plate riveted to the forward (I think) driver door post. Perhaps it can later be un-riveted and attached somewhere else on the car that's less offensive to the eyes - down on a chassis rail, for example.
TR3driver
Nope. CA has never had a problem with only one commission number. They only gave me a new tag for Stag #2, because the existing tag was obviously from another car.
And since unriveting it ("tampering") is against both state and federal law, I'm leaving it right where it is. No sense tempting fate a second time!
tinman58
When I registered our 250 The Lady at the CA. DMV could not understand the short vin number. She had never seen one so short. It took awhile but we did get the TR250 registered in CA.
charleyf
Regarding the short VIN number one of the stories around is that CA did not like the short numbers that we have on our cars and that is why some of the earlier cars also have a second tag which is STC1962 or what ever the date the car was sold. I believe it was to show what year the car was sold. One of my cars has this added to the VIN number while a second car also has a tag but the number is NOT added. But I have never been required to show any second tag on the car. I believe the first TR to have that is the TR6 ( found one on a '74) with a tag on the windshield.
Charley
JohnB
Bronze
DMV in California is so fun to work with!
Back in '54 when my TR2 was sold, either the dealer or someone at DMV copied down the commission number wrong. Instead of TS 4085 L
they wrote down T 54085 L. Fast forward to three years ago when I got the TR2 back on the road. I thought now is the time to fix that
registration number. Wrong! After sending paper work in twice, once with the actual numbers verified by a deputy sheriff and later again with the
correction noted by a CHP officer, DMV still has it wrong. I can't convince them that only 6,000 total TR2s were made, not the 54,000 plus that
their reg. number indicates.
I guess some battles are best walked away from.
martx-5
Many years ago I had a '67 Saab Sonett II, which was an early 3 cylinder, 2-cycle of which they made 258 vehicles before they went to the V4 engine. I had number 238, and that was the VIN number on the car...just plain old number 238. I don't recall exactly when Saab lengthened the VIN number to include the Sonett model designation of "97", but it was somewhere after the V4 was introduced. Another interesting fact about New York state is that there were no titles for cars issued before 1972, and they don't retroactively give them out. My TR3 has no title to this day, only a registration card that can be used to transfer the vehicle. How all of this would play in the Republic of California is anybody's guess.
groupdeville
Triumph commission numbers at least begin to look like "real" serial numbers to some DMV folks. Even long ago, it was highly "entertaining" to get the DMV to believe that a Morgan Plus Four's 4-number sequence really WAS the serial number of the car.
Overall, though, if having non-standard VIN numbers keeps our Triumphs out of the database-driven craziness that exists in many segments of the collector car world, then it's a benefit - even with the odd DMV tussle here and there. IIRC, the requirement for a VIN number in two (or more) places became a DMV-rule only 4 or 5 years ago.
T General TR Another trans popping out of 2nd Triumph 14
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
W TR6 Seat diaphragm failure on 2nd seat! Triumph 8
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
DerekJ Jack Rawles Racing at Zandvoort. From 6th to 2nd. Austin Healey 4
TR3driver TR4/4A New document available - TR4A Spare Parts Catalogue 2nd edition Triumph 5
Lotus Club SoCal 2nd Saturday Breakfast – Lotus Club of SoCal Activities Planning Meetings Lotus 0
doc50 TR2/3/3A Pops out of 2nd gear Triumph 7
Csarneson Source for BN4 2nd Gear Austin Healey 8
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
H 1st and 2nd gear problems Austin Healey 5
glemon TR5/TR250 Tranny Won't go into 2nd TR250 Triumph 13
B 2nd gear blocking ring failure BJ7 Austin Healey 5
F 2nd set of detail questions: 1963 BJ7 Austin Healey 21
Coyote1 2nd Gear OD or Not Triumph 19
dougie Cali Healey Owners - Sonoma June 2nd -5th Austin Healey 9
Jim_Gruber 2nd Grease Fitting on Fulcrum Pin Spridgets 5
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
EricG Sunbeam Gathering- Oct. 2nd, Columbia,SC Sunbeam (Rootes) 0
R lost 1st and 2nd! Spridgets 10
regularman 2nd condenser in a short time. Spridgets 13
B Last Green Valley Rallye, May 2nd Jaguar 5
H jumping out of 2nd gear Austin Healey 3
AUSMHLY Youtube...Finished my 2nd video....007 Healey Austin Healey 16
theleisure 2nd Gear, Please Don't Go Away! Spridgets 8
J Downshifting from 3rd to 2nd Austin Healey 7
T 2nd day of Amos Triumph 24
D no syncro 2nd advice MG 13
A Gearbox rebuild - popping out of 2nd advice? Video Austin Healey 18
Jayrz Poor Shifting 2nd gear MG 5
71tr TR6 Moss replacement 2nd gear bush - TR6 Triumph 0
Mg_Bizzle Considering 2nd hand engine, advice needed MG 26
Brosky 2nd Valley of Sin run SE MA & RI Triumph 0
fmichaels 2nd tranny rebuild inprog Spridgets 11
T Crypt Clutch 2nd Look-see Triumph 203
AUSMHLY 2nd gear Austin Healey 5
aeronca65t OT: Mother Ship is out of here! 2nd Diff broke! Spridgets 0
Shealey OT: Mother Ship is out of here! 2nd Diff broke! Other Cars 10
G 1st prize,3 days in July in TX, 2nd prize,5 days Triumph 9
zimmy wanted- 2nd gear for 1275 Spridgets 9
zimmy jollyroger -2nd gear for 1275 Spridgets 4
