TR5/TR250 Tranny Won't go into 2nd TR250
glemon
I think I am going to have to pull the transmission. The car often doesn't like going into second gear, and it seems to be happening more often.
Problem: Downshifting into 2nd often it like hitting a solid wall, on occasion upshifts too, but not nearly as often. Sometimes if works fine, up and down, on rare occassions it will go into gear with a big clunk.
I think I have ruled out hydraulic/clutch problems: I took up the slack in the linkage, no difference, it will shift in to all the other gears fine, never grinds going into reverse, I even tried going into reverse immediately after the end gear downshift block occured (after quickly coming to a complete stop of course), not problem, no grind.
If I slow down and shift into first it will shift into second after that fine. It will downshift into 2nd fine after I come to a COMPLETE stop, any rolling at all no go.
When I put a return spring on the clutch pedal it went away for a while so I thought it might be hydraulic (fluid return hole), but it came back and worse than ever.
So I really don't think it relates to the clutch or hydraulics but it someone really thinks they have a good argument or experiment will listen, don't want to pull the gearbox, but since the problem has only ever manifested itself in 2nd gear I am beginning to think that must be the issue, I rebuilt the box myself with all wear items synchronizers, bearings, bushings etc. replaced. (first time, maybe I just identified the issue!).
glemon
glemon
I think I have figured the problem simple but contrary to conventional wisdom on the subject, any guesses?
glemon
glemon
I didn't have time to post the answer, and I haven't had time to test thoroughly, but everything was making it worse, I was increasing the clutch release travel by futzing with the linkage.
When I first experienced the problem and through most testing I was pushing the clutch pedal down as hard as I could, seemed to make sense it the time, then I tried not pushing it down all the way, voila, problem went away, apparently you can get too much travel, don't know why it only manifested itself in second gear, maybe something to do with the direction of pressure I was putting on things or who knows?
Seems to be working great now, will futz a little more and drive a little more tommorrow, but I think I am on to something.
doughairfield
Glemon,
So glad you posted this, i'm having a very similar problem on my TR4. My problem specifically is that it's getting really hard to shift into 1st or when I'm starting out, or have been sitting at the stop light for a minute. I've also been really pushing the clutch pedal down hard or pumping it in an attempt to get the selector into gear.
Like you, I've taken up all the slack in the linkage from the slave cylinder to the fork lever and gone back and bled the system again.
I have noticed it helps a little to rev the engine up a bit and then try to get it into gear, but sometimes it takes 3 or 4 tries to get into first to take off.
I'm going to try your "push the pedal in slow" trick and see if that helps. Any additional insight will be much appreciated.
TR4nut
Doug-
In your case I'd be worried about the clutch fork pin not knowing anything else - or it could be a little wear on the pivot areas so you are not getting full disengagement.
Glemon's is more of a puzzler - I'm not sure why pressing more would bind 2nd. Very long shot thought, have you checked thrust washer clearance in the engine? Pushing harder would move everything forward, and potentially that would get the clutch plate to contact the pressure plate possibly. Or not, that is just a wild thought.
glemon
glemon
Doug your problem sounds like a hydraulic issue to me, if it gets worse after sitting a while you may have some leakage in your master cylinder or slave cylinder bores and the fluid leaks letting the cluth partially re-engage. When the car is not rolling and you are having trouble getting into first try reverse, if it grinds something is not fully released with the clutch.
Randy, I shouldn't have a thrust washer issue, engine is recently rebuilt, I haven't checked, but that would be a lot of wear in maybe 3000-4000 miles.
Went for a longer test drive today, all shifting just as it should. I will add that one of the experiments I tried was switching from 30w non detergent engine oil in the tranny to 90W gl4 gear oil. The shifting seems about the same, if anything the synchros feel a little slower, but that is very subjective.
The tranny does shift in and particuylarly out of O/D much smoother, which is nice, it worked fine but was kind of abrupt before.
Greg
doughairfield
Yes, after further investigation I also think it's a hydraulic issue. It has gotten very hard to get it into reverse as well as 1st from a dead stop. If I do about 5 quick pumps I am able to get the selector into 1st.
Both my master and slave clutch cylinders are less than 2 years old and I bled the system recently. Any suggestions on how to isolate which component is having an issue?
glemon
glemon
Pull the dust caps off the end of the slave cylinder and master cylinders, look for signs of brake fluid leakage, check your fluid level as well.
Greg
TR3driver
Great Pumpkin - R.I.P
Also look at the angle between the slave pushrod and clutch lever. The lever should tilt towards the slave, so the angle is slightly more than 90 degrees. If it tilts away, then you've got a bad TOB or, more likely, a broken taper pin.
On a TR4, you should also check the adjustment of the slave pushrod. You want only a very tiny amount of slack, when you pull the rod out against the force of the return spring. The book says 1/10" but I regard that as an upper limit. 1/16" is plenty.
Basically nothing can go wrong with the TR4 slave (unless it leaks, of course). But the MC has springs and a valve inside that can malfunction. If nothing else turns up, pull it apart and look for broken springs, etc.
doughairfield
Thanks guys.
I have not noticed any fluid leaking out of the slave cylinder and I was just under there 2 weeks ago to re-bleed it.
Hopefully tonight I'll have time to recheck the linkage and check that clutch lever angle.
If nothing looks amiss there, I guess I'll pull the master cylinder and check for problems there.
doughairfield
I was looking at the slave cylinder today just to make sure I had not made a dumb mistake a while back when I reconnected it and noticed I put it back in the mounting bracket upside down. Meaning that the bleed nipple is lower than the hose coming from the master cylinder. Could having the bleed nipple pointing down instead of pointing up prevent me form being able to get all the air out? Thus not being to ever get all the air out?
bgbassplyr
It will certainly make it much more difficult.
Kleykamp
Glenn, read the thread I have going. I feel your pain. I'm now in the process...slow as it may be, of removing the transmission to inspect internal clutch parts. I believe we have settled on it being the tapered pin in the clutch fork, among other potential clutch issues. Good luck, Joe
update: got transmission out...front grease seal leaking and grease on friction plate and all over inside of bell housing. Maybe not your problem but symptoms all sound very familiar. grease causing disk to stick, throwout bearing to stick, clutch to slip and any miriad of symptoms. Hope you resolve yours without having to remove the trans.
M Tranny Mount Bolts Spridgets 3
M Tranny Mount Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
R Tranny ? Spridgets 3
2 TR2/3/3A Oil leak in tranny Triumph 4
J TR5/TR250 tranny woes Triumph 15
Got_All_4 TR4/4A Interesting Tranny problem Triumph 9
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
Got_All_4 General TR This Happened Twice [TR6 tranny in a TR3] Triumph 17
F Ribbed case tranny in 948 bugeye Spridgets 2
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
histerical Datsun tranny help please Spridgets 18
histerical Tranny build Spridgets 0
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
GTP1960 TR2/3/3A tr6 Type A OD tranny service Triumph 10
C stupid question on tranny oil Spridgets 9
Got_All_4 General Tech How do i get these out? Tranny cover plugs Triumph 6
BillyB62 Sideshift OD tranny Austin Healey 15
Griz Tranny O/D Austin Healey 2
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
Got_All_4 General TR Identifing the tranny number on my j type Triumph 7
C TR2/3/3A Need Help Identifing Tranny with Overdrive Triumph 4
Rut 210 tranny Spridgets 10
T TR4/4A Want to buy tr4 tranny for my tr3a Triumph 17
R Od/tranny 100-4 Austin Healey 6
D Spitfire '65 Spitfire MKII tranny pblm Triumph 1
Tinkerman TR2/3/3A Continuity Check on Tranny Lock out switches Triumph 2
Tinkerman TR2/3/3A Tranny lock out switches Triumph 9
Got_All_4 TR2/3/3A J type on a TR3 tranny Triumph 3
Tinkerman TR2/3/3A Hole on top of my tranny tunnel Triumph 9
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
T TR4/4A Heat shield for tranny cover Triumph 4
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
RJS General TR Valvoline VR-1 20W-50 or Straight SAE 50 for OD Tranny? Triumph 16
Lukens TR2/3/3A TR3 A tranny questions. Triumph 8
J TR4/4A Can't get the TR4 tranny and OD to mate up Triumph 12
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
L Overdrive and tranny oil Austin Healey 19
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
C Tranny dip stick question Austin Healey 11
R TR2/3/3A Will this Tranny fit my TR3 ?? Triumph 9
