1960 AH 3000, VIN help ?
McMahonRacing
I know for most this may be some what repetitive but, I don't have the books that most do and need a bit of help w/o spending a bunch of cash:
Back story, bought a beat up 1960 3000 back in 2006, transferred the registration to my name and promptly put it in storage ( I did it in NH to ease the transition to MA at some point ), long story short the car has now been sold to a large seller of cars and they have found the VIN on the registration to be wrong and there is no VIN plate but there is a body plate, all info I have is as follows:
Old Reg # HBN7L8214 (think this should really be BT7 & this is what we are trying to correct )
Body Tag # 3095BT7, 18079, L ( I think the 3095 is in the correct series of body #'s for 1960 )
No engine #
Has triples on it
Is a 4 seat body
Has a hard top
Specific questions:
Are there any other #'s on the chassis/body that are VIN related ? (ie: would be great if this was listed somewhere on line clearly stated, what I have found to this point is a bit confusing esp. w/ the crazy build structure they had at the time )
Is the only real option to get a Certificate using the body # ?
Does any one have info. that would help show any of these #'s correct ( ie: assuming that correct should be BT rather than BN ), maybe something electronic that I can use as supporting documentation to approach the local Registry to request the letter change ?
Any other thoughts would be greatly appreciated.
Thanks
Pat
CLEAH
Pat,
A few initial observations. A BT7 with triple carbs would make it a MkII 3000 made between May '61 and June '62, not 1960. Also, the body number of 18079 falls in the '61-'62 range also. You can find the Commission number (the serial number you are looking for) stamped on the right hand spring tower, just below the shock absorber (I know that this is true on my BJ8, I think it is there for the earlier 3000's also).
The 8214 Comm number you have puts it in the Mk1 1960 range. Of course, you have the number, but not the plate. Getting a Certificate with the body number is a good step, but it might just show that the car is a bitsa. Check the spring tower. Others will chime in if that number is not stamped on the earlier cars.
HealeyRick
Hey Patrick,
I believe the chassis number is stamped by the shock tower only on the BJ8. I think your only option is to obtain a British Heritage search by body # (18079L) here: https://www.heritage-motor-centre.c...certificates/car-traced-with-body-number.html That should get you the chassis number and you can get a new chassis number id plate stamped here: https://www.clarkespares.com/carparts.html Of course there's no guarantee that the real chassis number for the car is the same as the BN7 number that you have a registration certificate for with just a change to "BT7" Lots of games were played with VINS with these cars when they were just used cars and sorting the out can be a pain. Probably not the low-buck option you wanted to hear, but I think it's the only way.
BTW, don't know if I told you that I got to show your dad my Ford conversion up in Maine last fall. He said nice things about it so I was pretty happy. Hope everyone's well.
BoyRacer
Pat,
I may have a solution for you. We should talk about it over the phone. Send me a private message and I'll give you a call.
Richard
Rob Glasgow
I once looked for the chassis number on my 1960 BT7 right shock tower and did not find anything. I think it was stamped there only on later cars.
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G 1960 3000 BN7 Top Help Austin Healey 0
L Request help with identifying this AH 1960 3000 part. Austin Healey 1
M signal lamp replacement - 1960 austin-healey 3000 mk1 Austin Healey 6
L 1960 Austin-Healey 3000 on "Chasing Classic Cars" Tonight Austin Healey 3
Gray_Cat 1960 AH 3000 For Sale in Glendora CA Austin Healey 0
B 1960 AH 3000 BT-7 [Top Stowage Area Rug] Austin Healey 3
B Hard starting 1960 AH 3000 BT-7 Austin Healey 6
AUSMHLY Dash panel color scheme 1960 3000 Austin Healey 7
J Need a replacement head for a 3000, 1960 ?? Austin Healey 2
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
dougie 1960 3000 MK I Historic Racer Sold for a Song Austin Healey 4
coj Motor Mounts AH 3000-1960 with 29 F engine Austin Healey 6
coj Engine mounts 1960 AH 3000 with 29 f ENGINE Austin Healey 1
O 1960 Healey 3000 BN7 front hood/bonnet Austin Healey 2
B 1960 Healey 3000 Seat Belts Austin Healey 10
L FUEL PUMP FOR 1960 MKI 3000 Austin Healey 12
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Pool Dad 1960 TR3 engine serial number Triumph 14
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
J 1960 Bugeye Paint Codes Austin Healey 1
K MGA 1960 MGA Vin MG 3
F 1960 FriskySport Barn Find Other British Cars 6
5 Proud of my 1960 Bugeye Spridgets 5
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
P 1960 Lancia Appia coupe Other Cars 1
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
