Hard starting 1960 AH 3000 BT-7
B
Bobbee44
I have a 1960 BT-7 that is a real pain to start when cold. It starts and runs beautifully when warm, but takes a lot of coaxing (read feathering the accelerator) to get it warm enough to continue at idle. It is equipped with an "automatic choke," that I believe works, but perhaps not too well. Does anyone have a cold start procedure thay would share with me?
Thanks,
Bob
From the Moss catalog, Twin HD6 carbs page, AUC935 drawing -- it looks like these carbs have the same mixture screw at the bottom as the other HD6 carbs. You could try screwing each of them down by a full turn then starting. This would richen the carb like a manual choke. If the car becomes easier to start you know the problem is in the chokes and can act accordingly.
Steve:
Thanks for the site. I am going to give the mixture control on the starting carb a twist or two thi weekend. Should the adjustment not prove beneficial, I will resort to a trip to my friendly British car garage and, I am sure, a new solinoid.
Thanks again,
Bob
Steve:
A somewhat belated reply. I studied the schematic you provided and went on line to a British SU site and found a similar schematic. Cutting directly to the chase, I followed the directions on setting up the auxiliary carb and the Healey starts now as well as any fuel injected car I'v ever owned.
Thanks again,
Bob
S TR2/3/3A TR3 Hard Starting Triumph 4
D Hard Starting Austin Healey 14
R winter hard starting BJ7 Austin Healey 16
P TR6 TR6 hard starting Triumph 24
S Hard starting on Webers from cold Austin Healey 12
P TR6 Follow-up to hard starting Triumph 4
P TR6 hard starting Triumph 23
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
R hard starting Austin Healey 8
TR3sharon TR2/3/3A Hard starting when hot Triumph 9
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
S BJ8 hard starting when warmed up Austin Healey 11
J Spitfire 78 Spitfire hard starting Triumph 2
Thor Suggestions for hard starting 1500 when cold Spridgets 5
roofman Spitfire Hard starting Spitfire Triumph 12
Stewart Backfiring stalling and missing hard starting MG 5
D MGA MGA hard starting sometime backfires MG 2
E hard starting-engine quits Spridgets 14
R Hard starting problem Austin Healey 2
W Hard starting Jaguar 5
W Hard starting in the cold Austin Healey 4
txtr3 TR2/3/3A TR3 hard starting, but has been running ok Triumph 11
G Hard starting, but then runs fine MG 6
S 57 T-Bird hard starting when hot Other Cars 5
J Hard Starting vs Fuel Austin Healey 3
W hard starting when hot MG 7
L T-Series Hard to start MG 11
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
KVH TR4/4A Hard Start When Engine Hot Triumph 20
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
K TR2/3/3A Hard start questions.... Triumph 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
