hard starting
Roberte
Member
My BJ7 has become extremely hard to start after leaving it for a day or so. After it has finally been started and warmed up there is no further problem. I wonder what might be the cause as well as the cure.
Robert
I would revisit my timing and choke settings
A common 356 Porsche problem is starting after a few days/weeks of non-use. The modern fuels tend to evaporate more readily and the the fuel bowls dry up. I've just fitted an electric pump inline to prime the carbies (on the 356) - once it starts the mechanical pump is fine. In fact the mechanical pump will start the car too - but takes some cranking to push some more fuel into the carbies, as the pump only works when the engine is turning over. Needless wear and tear on the starter. My Healey has an electric pump so I can't say whether this happens on my Healey.
I guess all Healey pumps are electric aren't they, so my last point is superfluous...
I have a similar problem with my 62 BT7. If the car has been run anytime in the previous few days, it starts fine. After a few days of sitting, though, it requires about 5 or 10 secs of cranking (which is actually a long time to crank, I think) before it finally starts. In all cases, I wait until the fuel pump stops clicking so that the float bowls are full.
Since the engine is completely cooled off after 24 hours, but the car starts fine, I have assumed that the problem is caused by evaporation of fuel in the intake manifold and cylinders after several days, but maybe this is a bad assumption.
I agree with Keoke
My experience of the same problem was timing - it was way out, worth a visit and easy to correct.
:cheers:
Bob
I would have thought that a timing problem would make the car hard to start most of the time, not just after sitting several days. My car is set at 15 BTDC at idle, and it fires right up as long as it's been run in the 24-48 hours previously. I'll check it again this weekend, but I'm pretty sure I got it right.
Keith
In my case hard starting was when cold, after eventually starting - 3 - 5 minutes ish the car would run and would start again easily, even if it was started in the morning, run, put away again in the morning and started later in the day. However after a day or two back to the 3-5 minutes start up. Once the timing was set there were no problems, save a little difficulty in the winter - 2nd or 3rd time on the button.
:cheers:
Bob
S TR2/3/3A TR3 Hard Starting Triumph 4
D Hard Starting Austin Healey 14
R winter hard starting BJ7 Austin Healey 16
P TR6 TR6 hard starting Triumph 24
S Hard starting on Webers from cold Austin Healey 12
P TR6 Follow-up to hard starting Triumph 4
P TR6 hard starting Triumph 23
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
TR3sharon TR2/3/3A Hard starting when hot Triumph 9
B Hard starting 1960 AH 3000 BT-7 Austin Healey 6
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
S BJ8 hard starting when warmed up Austin Healey 11
J Spitfire 78 Spitfire hard starting Triumph 2
Thor Suggestions for hard starting 1500 when cold Spridgets 5
roofman Spitfire Hard starting Spitfire Triumph 12
Stewart Backfiring stalling and missing hard starting MG 5
D MGA MGA hard starting sometime backfires MG 2
E hard starting-engine quits Spridgets 14
R Hard starting problem Austin Healey 2
W Hard starting Jaguar 5
W Hard starting in the cold Austin Healey 4
txtr3 TR2/3/3A TR3 hard starting, but has been running ok Triumph 11
G Hard starting, but then runs fine MG 6
S 57 T-Bird hard starting when hot Other Cars 5
J Hard Starting vs Fuel Austin Healey 3
W hard starting when hot MG 7
L T-Series Hard to start MG 11
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
KVH TR4/4A Hard Start When Engine Hot Triumph 20
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
K TR2/3/3A Hard start questions.... Triumph 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
