TR2/3/3A TR3A gas tank repair
JAJohn
Member
Bronze
I took out the gas tank of my TR3 that had been sitting in a garage for 40+ years. Top and sides of the tank solid, but on the bottom near the fuel line tube it's rusted through, leaving a hole the size of a quarter. Anything I can do? I can weld.
Then, what do I do about the fuel line to the engine? How do I clean it out? Or is replacing easier?
TR3driver
Great Pumpkin - R.I.P
I have been known to repair TR3 fuel tanks with soft solder, and in one case a patch cut from a 'tin' can. No reason you couldn't braze or weld, that was just the method I had available at the time. You'll probably want something thicker than an old soup can to mount the outlet bung, though.
Both repairs worked out well. One of the cars got wrecked and junked about 5 years later; the other was still holding fuel over 20 years later.
The trick is be certain there are no traces of fuel left inside. I flushed with running water (stuck the hose in the filler and let it overflow out the sender hole) until I couldn't see any colored stripes in the water; then drained and left it in the sun to dry. Repeated the exercise the next day, just to be sure. No fuel odor inside the tank at all (otherwise I would have done it again).
I just blew the lines out with compressed air. Worked for me, YMMV.
TomMull
My choice would be to get a new tank. Same with the fuel line. The tank can be welded but follow all the rules as it is dangerous. I weld also but no fuel tanks. The tanks also tend to get rust and crud in the seems and are difficult to clean and seal.
The tank for the earlier TR3A,s are reasonable at about $275, the post 60k cars nearly twice that; maybe only ally or stainless available. Shipping will be expensive also.
Tom
J
JAJohn
Member
Bronze
No worry about anything other than dust inside. It sat for years. I found a small screwdriver rolling around in it.
CJD
I had an ebay tank that I tried to use. After pulling it 5 times to repair different leaks, I bought new. Best decision I made. Once they reach a point they get holes, it is hard to repair all the rust pinholes, unless you are willing to patch the entire bottom.
Chasman18
I purchased a new tank for my 59 TR3A. Alas, and my error, gas outlet on wrong side. It appears that I can still use the tank; however sending unit and breather tube now on left side instead of right. Any issues with making this adjustment? Wiring no issue, easy to drill hole in floor for breather tube. Any other issues? Thanks from an amateur restorer.
TomMull
1. This is an old topic. You should post this as a new topic. The only people who will see your reply are those who followed this one in the past.
2. I have a similar tank which I bought on sale somewhere and never used. This one has a center outlet and a right outlet. It also has no hole for the gauge. The tanks for the pre-60,000 commission numbered cars (My 59 TR3A is one of those) and the later cars are different.
That said, I think your plan is good but I can't speak from experience.
Tom
mctriumph
My funny story of cleaning a tank for a customer. The tank did not leak until the rust
has been dissolved, then it leaked everywhere!
I say from bitter experience, if there is more than a little rust visible inside a tank, it's
JUNK! Cut to the chase, it will save time ,money grief and alcoholism....
Mad dog
PatGalvin TR2/3/3A TR3A Gas Cap Info and uel tank venting Triumph 4
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
T TR2/3/3A TR3A Gas Cap Triumph 15
M TR2/3/3A TR3A gas cap fiber washer Triumph 6
Tinkerman TR2/3/3A TR3A 1960 Gas on three out of four plugs ? Triumph 6
G TR2/3/3A TR3A Gas cap help Triumph 14
T TR2/3/3A TR3A gas gauge stuck in "Full" Triumph 26
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
