TR2/3/3A TR3A 1960 Gas on three out of four plugs ?
Tinkerman
I started my engine yesterday after about a 2 or 3 month layover. It started well and ran well. Today I pulled the plugs and all but the #2 plug were wet with gas. What are the typicall reasons for the plugs being gas soaked? This is a brand new re-built engine with re-built and re-shafted carbs. I'm very happy that it started well and ran well, BUT I feel that the gas on the plugs is not good.
Your thoughts and ideas greatly appreciated.
Tinkerman
CJD
That would be normal if the choke was on and the engine never reached operating temperature.
sp53
Yes TR3 chokes need to be just right. Try and make sure you do not run it rich especially over the break in period. I always double check and make sure the jet returns until I feel comfortable it is returning on its own.
Tinkerman
Tinkerman
"I always double check and make sure the jet returns until I feel comfortable it is returning on its own. " OK makes sense, how do I do that?
Thanks, Dick
M
Member 10617
One thing to do is to check the jets after pushing the choke off to see if they are all the way up. If not, sometimes it is because the return springs are not strong enough, either because they are old or just too weak. I have found that springs from the different major suppliers all have markedly different tensions.
Also, sometimes you need to work the jets up and down a bit if the carbs have been rebuilt, just in case the cork gaskets are too stiff. Also, if the corks were not left in an oil bath for about 24 hours before installing them, they could be too stiff and aare keeping the jet from returning fully up.
When your engine was rebuilt, were the carbs rebuilt at the same time?
Quite often when these carbs are rebuilt, the person working on them fails to remove the old cork seal at the very top of the jet assembly (#92 in the illustration on p. 24 of the Moss Catalog). They cram another seal up there thinking that it is clear, and the added thickness keeps the jet from fully rising to the top. This is probably not your problem, but it is worth considering if the problem is with the jet not returning fully.
Just a thought...
sp53
Just take your finger and push the center of the adjustingnut on the bottom of the carb and it should side right up.
Tinkerman
Tinkerman
Yep, jets are free and working as advertised. Tomorrow I am going to start it and let it run for 15 to 20 minutes. After it cools down I will pull the plugs and see what I have.
Will let ya'll know how that comes out.
Cheers, Dick
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
W For Sale 1960 TR3A for sale Triumph Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
Tinkerman TR2/3/3A 1960 TR3A carpet installation Triumph 5
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
Tinkerman TR2/3/3A Prepping the grill for installation for my 1960 TR3A Triumph 1
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
Tinkerman TR2/3/3A 1960 TR3A Bottom Rubber Seal on the Windscreen Triumph 3
Tinkerman TR2/3/3A Tunnel installation question 1960 TR3A Triumph 11
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
Tinkerman TR2/3/3A Carpet underlayment, TR3A 1960 Triumph 10
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
Tinkerman TR2/3/3A 1960 TR3A post 60,000 series seat pan covering Triumph 3
Tinkerman TR2/3/3A 1960 TR3A seat tack strips Triumph 1
Got_All_4 TR2/3/3A Finish on a 1960 TR3A Fluid reservoir? Triumph 6
60TR3A TR2/3/3A 1960 TR3A Small Mouth [Huh?] on eBay Triumph 63
M_Pied_Lourd TR2/3/3A 1960 TR3A Mystery G Triumph 24
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
M_Pied_Lourd TR2/3/3A Restoration of TS 69891LO 1960 TR3A Triumph 36
T TR2/3/3A 1960 TR3A oil leak issue [imagine that!] Triumph 5
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
PAUL161 TR2/3/3A Colonal Tom Parkers 1960 TR3a For Sale! Triumph 3
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
Tinkerman TR2/3/3A Bulkhead Sealer Plate TR3A 1960 Triumph 3
D TR2/3/3A 1960 TR3A Paint Question Triumph 24
gubba TR4/4A 1960 TR3A with tr4 motor and tranny? Triumph 22
D TR2/3/3A 1960 TR3A Flasher Triumph 7
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
