TR2/3/3A TR3A Cowl Vent Spring
nealm
I was wondering if anyone could tell me how the cowl vent spring attaches on a 1960 TR3A? That's the spring that holds the cowl vent door open. Better yet does anyone have any pictures?
Thanks
NealM
martx-5
That's a real head scratcher when you first look at it. Basically, the closed horseshoe shaped end hooks into between the the tabs of the front assembly, and the body. The rear of the spring with the two ends sticking out hook into the lid.
See the attachments below, and it will be a little more clear. I just did a quick assembly of the parts, and left out the rod that actuates the lid.
Hope this helps.
Edit: You will also notice that I did not attach the front assembly fulcrum piece (the part laying down in the vent cavity) to the lid itself. IIRC, that attaches with a fat cotter pin. At least that is what was in there when I took it apart.
Geo Hahn
martx-5 said:
...IIRC, that attaches with a fat cotter pin. At least that is what was in there when I took it apart.
On mine that is held with a pin (sort of a bolt w/o threads) and speednut. No idea if that is original.
My lid will not lift as far as the one pictured, the springs are too tight for that. Also, I had to oval out the holes where the hinge attaches to the body to get the lid back far enough to clear the rear edge of the bonnet.
Of course the one pictured lacks the rubber seal, that needs to be in place before you hook up the springs.
martx-5
Like I mentioned in my post, I just put together things quickly in order to show how the spring was situated. Yes, I left out the gasket/seal, and didn't even attach the lid to the body, or the actuator to the lid. That alone would have brought the lid down. If everything was hooked up, the lid would only be up about half of what it shows in the pics. The original poster was concerned about how the spring went on. I tried to show that, and wasn't concerned about the rest of the installation.
WillE
Here's a pic I took before dismantling my 2 - hope it helps!
Note that the spring is 180deg from the one shown by martx-5
martx-5
That's interesting...about the 180 deg difference. When I first tried to assemble the pieces with the way they are shown in WillE's photo, the lid would not close easily for me. I flipped the spring, and then it closed with a nice snap, and opened without a problem.
Try it both ways, and see which works best. I'd like to know, as I will be confronted with putting all of this together soon enough.
Don Elliott
If you find that it's hard to close, just reach over the top of the windscreen and pop it closed. Takes only one finger and only a second, but keep you eyes on the road, especially if you're talking on your cell phone as well.
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Hamish Racing TR2/3/3A TR3a video Triumph 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
angelfj1 TR2/3/3A TR3A Stone Guards Triumph 3
Hamish Racing TR2/3/3A 1959 TR3a used in anger Triumph 5
