TR2/3/3A TR3 SU float bowl grommets.
karls59tr
Bronze
Anyone else heard of a bad batch of these grommets that were made of soft rubber that would swell up and partially block the fuel flow?
PeterK
Only problem I've had with these is that, if you tighten then too much or too little, they will plague you with a slow fuel drip. Never had the swelling but might be that some mfg used the wrong type of rubber.
All mine were purchased from Moss.
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
E TR2/3/3A TR3 carb float bowl Triumph 5
BillyB62 TR2/3/3A Front Float Cover Lid for TR3 H6 Carb Triumph 10
D TR2/3/3A tr3 float chamber Triumph 5
T TR2/3/3A TR3 axle end float Triumph 5
K TR2/3/3A TR3 Front end..wishbone assembly end float??? Triumph 2
eschneider TR2/3/3A empty float bowls - TR3 with twin SU H6 carbs Triumph 19
White79MGB TR2/3/3A TR3 Rear Axle end float setting Triumph 7
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
