TR2/3/3A TR3 speedometer repair
bobhustead
Speedo on my TR3 has to warm up to work at all and will not indicate over 20 mph in any case, although the indicated speed is proportional to road speed. Adjusting screw got it raised to the mentioned 20mph, but that's it. Anyone know a repair facility?
Bob
TR3driver
Great Pumpkin - R.I.P
What adjusting screw?
Lots of places work on them; here's a couple I have handy:
North Hollywood Speedometer & Clock Co.
6111 Lankershim Blvd.
North Hollywood, CA 91606
Phone 818-761-5136
Fax 818-761-4857
https://www.nhspeedometer.com/
MO-MA
1321 2nd St NW
Albuquerque, NM 87102
(505) 766-6661
momanm@aol.com
B
bobhustead
Looking at the speedo from the rear, immediately left of the cable is a slot head screw. There is a hole in the retaining bracket to provide access. Is my 30 year old recall of its function faulty?
Bob
CJD
Nope, not an adjustment! Nisonger will also work on them, but they're not cheap.
https://www.nisonger.com/
John
Oh, it sounds like the grease in the unit has hardened, so a good cleaning may be all it needs. If that doesn't fix it, then the magnet has likely weakened over time. Luckily it can be re-magnetized by a speedo shop.
sp53
Well if reads at all that is good thing because the main spring is not broken. In the day and I was at a swap meet, the to test to see if it was worth buying cheap as a possible good one was to hold it in your hand, and twist your wrist. If it bounced back, the main guts were in tacked. I would try and fix yours by removing the front glass and the two screws in the back to see if the rubber grommets have dissolved and got on the cup. You can clean that with brake clean. I say this because when you send yours off to get fixed, they often send back one that is a rebuild off the shelf. I have remove the jewel workings in many and got them working fine. It is a little complicated, but not that bad.
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
O TR2/3/3A TR3 Speedometer Cable length? Triumph 5
G TR2/3/3A Tr3 Access Needed to Replace Speedometer to Overdrive Triumph 2
T TR2/3/3A tr3 speedometer glass Triumph 9
K TR2/3/3A TR3 Speedometer just quit? Triumph 6
V TR2/3/3A TR3 OD Speedometer Part Needed Triumph 10
S TR2/3/3A tr3 speedometer Triumph 6
S TR2/3/3A Speedometer cable tr3 Triumph 3
S TR2/3/3A tr3 speedometer trip reset Triumph 5
S TR2/3/3A TR3 speedometer and wheel revs per mile Triumph 6
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
