TR2/3/3A TR3 Speedometer Cable length?
TR3driver
Great Pumpkin - R.I.P
With or without overdrive?
TomMull
The cable housing on mine, non od, is about 61 inches. Tom
TR3driver
The cable for and OD TR3A is 96 inches.
Only for LHD. The cable comes out through the firewall in front of the instrument, then turns and runs along the ledge in front of the battery then down along the RH frame member under the car. Big smooth turn there to come up through the teardrop shaped hole around the handbrake and back through the tunnel to go onto the OD. Should be a clip on the battery ledge, and I think another one on the RH frame rail.
You can see (barely) in this shot the original clamp on the ledge, on TS39781LO
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
S TR2/3/3A Speedometer cable tr3 Triumph 3
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
G TR2/3/3A Tr3 Access Needed to Replace Speedometer to Overdrive Triumph 2
B TR2/3/3A TR3 speedometer repair Triumph 5
T TR2/3/3A tr3 speedometer glass Triumph 9
K TR2/3/3A TR3 Speedometer just quit? Triumph 6
V TR2/3/3A TR3 OD Speedometer Part Needed Triumph 10
S TR2/3/3A tr3 speedometer Triumph 6
S TR2/3/3A tr3 speedometer trip reset Triumph 5
S TR2/3/3A TR3 speedometer and wheel revs per mile Triumph 6
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
Top Bottom
