TR2/3/3A tr3 points& condenser#'s
TFB
Does anyone have the napa numbers for points and condenser DM2 dist?
I usually get them from Moss or Jeff at Advanced but would like to pick up a set today if possible and quality is the same.
Thaks
Tom
TomMull
Try ECH CS207A. I have used them in the distant past with no issues.
Tom
T
TFB
Thanks for fast reply Tom.
I found an old post after my post which also gave the condenser # ech ep29 and some other replacement part numbers.( thanks tdf1250dave 2010)
Napa has in stock about $14 for both.
Thanks aain
Tom
T
TFB
Thanks sp53 ,I wasnt sure the date range of points in the variations of distributors.
BTW the Echlin points from Napa had bigger contacts than the Moss unit and a slightly different design with one flat contact and the other with a hole in the center,kind of pancake on a sliced bagel.Appears more substantial,dont know if its better.
Tom
Geo Hahn
Thanks sp53 ,I wasnt sure the date range of points in the variations of distributors...
Often a large range. For example, a 6-cyl E-Type uses the same points (and condensor and base plate) as the TR3 & TR4. When you think about how a distributor works it is the cam that determines the number of cylinders and the weights that control advance. Not much variation where points are concerned.
groupdeville
And in an emergency, you can always buy a Volkswagen beetle condenser from your FLAPS and wire it up outside the distributor, after removing the defective internal one. Beware of current-production "orange wire" condensers, as they seem to have a higher failure rate than other units. I've had several of these go bad over the past five or ten years.
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
G TR2/3/3A TR3 Grease points Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
O TR2/3/3A Best jack points/location stands TR3 Triumph 4
W TR2/3/3A TR3 Jack points Triumph 18
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
