MGTF1250Dave
Aloha All,
Driving to work this morning my TR3 failed to proceed. The engine died and I was able to move to the shoulder without incident. The starter turned the engine over rapidly but it would not start. I checked the fuel side and the pump is working well and fuel to both carburetors. The problem seems to be on the ignition side and I suspect it is either the coil or a broken wire in the low tension circuit. The points are opening and closing as the distributor turns. A friend help me tow it home and I work on it tonight after work.
I had only a screw driver and a crescent wrench (adjustable spanner) so I was limited in trouble shooting electrical items.
