doughairfield
Today I was bolting the timing chain sprocket to the front of the cam shaft just now and was tightening the 2 bolts down. As I got to 20ft/lbs I stopped gaining any additional torque and then one sheered off, with most of it inside the camshaft. I followed the torque spec from my manual for the "Timing Chain Wheel to Camshaft" which I have as 24-26 lbs. ft. Did I misunderstand something here about the torque?
So where do I go from here? I've got the end of the bolt inside the camshaft, can I just use a screw extractor to get it out? Should I not have reused those bolts?
