starting problem
Went to start my BJ8 this morning and it turned over for a second with out starting. All power seems to be on. Remote starter cranks nicely. Will crank with the key now. I'm guessing the ignition switch or wires from it have gone bad. (Fuses seem OK) Any other places to look before I have to remove the radio and all? I hate all the spaghetti wiring behind that panel. Fix one wire and pull two others out.
TH
Hi Rich,
With the key on, check the white wires at the fuse block for voltage. If yes, your switch is most likely OK for another hundred miles.
Hi TH,
I am a little confused. Will it crank using the key-switch? Although you seem to indicate it will, the rest of your post seems to indicate the opposite. Will the car start with the key in the run position and starter activated by the solenoid button?
If the ignition key does not trigger the starter and all other switched-power components function (unit only work with ignition on i.e. wipers, etc.), then you are getting power to the switch. If you receive 12v at the solenoid with the ignition switch at start, your ignition switch is OK and the solenoid is at question. If no power is present at the solenoid when the key is at start, the line or switch is bad.
If no switched power components are functioning (or 12v is not present at the white wires connected to the fuse block), with the key in the run position, your switch is defective or is not being fed power from the regulator. If no power is at the switch, I would check the brown wire connections at the switch and regulator.
Based upon my experiences, I would check connections at the solenoid and regulator first.
All the best,
Ray 64BJ8P1
Thanks for the fast responses.
When I first tried to start it the key did crank the engine but never fired. Then it stopped and would not crank again with the key. It will crank with the remote starter. I have not tried Greg's suggestion yet. I am also suspicious of the solenoid. I will also be trying Ray's suggestion. I just ordered a new solenoid from Moss 10 minutes ago. Norman Nock thought it sounded like a problem 2 years ago and walked me through a "fix" (just banged it with a screw driver handle I haven't tried that yet, either). I really don't remember if it was the exact same problem.
Again thanks for the fast help.
TH
:savewave:
Hey TH, What happens when you press the little button on the end of the solenoid ? Does it crank good? If so Normans shock treatment may work ,also a bit of penetrating oil around the cylinder may do it too.--Fwiw Keoke
Well, I banged the solenoid with a small hammer and it worked. Thanks, Norman. Once again you have come through for me. I will carry the new solenoid in the boot cause I know this will happen again. This does not mean that I don't have a poor connection somewhere which I will be checking out.
Thanks for all the help.
TH
You don't need a spare solenoid or fuel pump.
Just a hammer, right?
Lutz Kramer Problem starting the cold engine Austin Healey 16
S BJ8 Hot Starting Problem Austin Healey 25
Mowgli81 Starting Problem Ignition coil? Dist. Cap? Austin Healey 21
D frogeye starting problem Austin Healey 2
J Spitfire Hot starting problem, 78 Spitfire Triumph 7
mgbmedic Wedge Triumph TR7 Starting Problem Triumph 4
roofman Spitfire 75 spitfire starting problem Triumph 6
B TR6 TR6 starting problem Triumph 24
P Starting problem .. and a burning problem?? Austin Healey 11
C MGB Wierd starting problem - 77 mgb MG 4
R odd starting problem Spridgets 1
T Novice seeking advice on starting problem Spridgets 32
R Hard starting problem Austin Healey 2
LastDeadLast Help me with a starting problem Triumph 17
R Starting problem MG 6
R Cold Starting Problem for a BJ7 Austin Healey 4
B Healey starting problem Austin Healey 19
B Starting Problem Spridgets 6
catfood Starting problem solved, but... Austin Healey 1
W Starting Problem Austin Healey 4
M Intermittent starting problem Jaguar 1
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
