Wedge Triumph TR7 Starting Problem
mgbmedic
WEnt for a short drive in my 1980 TR7, after sitting for 2 hrs, tried to start it and...starter bendix hung up, Engine ran but wouldn't stop, starter stayed engaged, had to remove battery cable to get it to stop. Had starter rebuilt... no change. Replaced ign switch...starter still stays engaged, but can shut engine off with key. This is a big improvement, but still not fixed. Traced wiring for dead short, as battery drains when parked. Traced to starter relay without finding any obvious problems. Could the relay be the culprit? How do you test relays? Any help will be appreciated.
Hi I refurbish Lucas starter at my business and from your description of the problem it sound to me you have a defective starter solenoid. You said you had the starter rebuilt. Was a new solenoid installed at that time? Also there is a possibility that the starter drive is staying engaged because the teeth may be not engaging correctly into the flywheel and grinding. If a new solenoid was not installed at the time of the rebuilt on the starter my bet is a bad starter solenoid. If I can further assist you can always contact me.
Mike Martinez
Star Auto Electric
www.starautoelectric.com
I put the wrong relay in the fuse panel once for the starter and it would stay engaged while the key was on. Did you replace any relays lately?
The starter relay is the round blue one. Replace it with another and see if it fixes the problem. It needs to be one of the blue relays- the black ones are different.
Just drove the car for a short hop to the grocery store, came home, let it sit...problem occured. Are these relays available locally, or Lucas specific. Someone did point out that I had no brake lights...connection to starter? It is the round blue one, not the square aluminum one. And, it's a new solenoid. Thanks for your help, I'll try replacing the relay tomorrow and let you know then.
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
Andrew Mace Wedge Up-date: Another Triumph [TR7] back on the road! Triumph 5
John_Mc Wedge Triumph TR7 "Sport"... Triumph 7
chrisc Wedge Triumph TR7 The Untold Story Triumph 1
T Wedge Need a Triumph TR7 FHC for a TR8 conversion? Triumph 13
Hegg Wedge Triumph TR7 Model Cars Triumph 4
T TR4/4A Triumph TR4A 1965 price Triumph 8
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
L My 1951 Triumph long ago British Motorbikes 0
tr6nitjulius TR6 TRIUMPH invades Redmond, Or for ATDI 2023 Triumph 4
Hamish Racing General TR At last a New Triumph Triumph 2
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
XJtom General TR Triumph items of interest Triumph 2
B TR6 Triumph tr6 coolant leak Triumph 4
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
Gliderman8 General TR Triumph emblem? Triumph 13
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
