Spitfire 75 spitfire starting problem
roofman
I haven't gotten around to posting pics yet but I bought both a 75 and 80 spitfire, and am selling the 75. I have been starting it( the 75) every day including this morning but I ran it out of gas. I went and put 2 gallons in but now will not start. Plenty of cranking power, just will not start. Has new dist.cap and rotor, points look good and it started fine this morning. It has been cranked for 5 minutes and will not start. WHere should I look?
Given that you ran it out of gas before it wouldn't start, I'd be looking at fuel delivery. Sometimes the fuel pumps will move gas just fine, but not air at cranking speed.
What I usually do after running out of gas is to pour just a little raw fuel directly down the carb throat(s). That should let the engine start and run for just a second or two, which is usually enough to get fuel worked through the lines & pump.
Thanks tr3driver, I got it off the hill it was on to flat ground, found an old can of starting fluid either, and between the 2 got it cranked. I think it just needed more time for the fuel lines to fill up. The trucking company the buyer has contracted to get the car is coming today so murphys law came into effect for me, but it's going. Will post pictures of the 80 spitfire as soon as I get time.
Thanks thread closed.
Randell, I periodically run a script to see which users are over their PM limit. Just FYI - you are currently at your PM limit. Until you delete some PMs you won't be able to receive any additional PMs. Just FYI.
Thanks for the tip, Basil. I forgot totally about the need to clean them up.
Roofman - I had a similar thing happen on my '74 Spit and it turns out I sucked some gunk from the bottom of the tank and it clogged the electric fuel pump that was installed by the PO.
It might be that simple...
Basil,
Like that avitar much better than the pooch. The pooch gives me the creeps.
J Spitfire Hot starting problem, 78 Spitfire Triumph 7
J Spitfire 78 Spitfire hard starting Triumph 2
roofman Spitfire Hard starting Spitfire Triumph 12
S Spitfire starting a barnfind spitfire Triumph 8
T Spitfire Starting my 1500 Spitfire Triumph 17
J Spitfire spitfire not starting, cap and rotor Triumph 4
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
