Starting problem solved, but...
catfood
Gentlemen,
Thanks to your advice I checked out the choke mechanism on the BN1 and found that full choke only pulled the levers about a quarter of an inch. I've now adjusted it so that I get more 'pull' and she now starts after turning over a couple of times.
However I did notice that when everything was disconnected that full travel of the rear carb choke lever was about 5cm whereas the front carb was only 3cm. Is this correct/normal.
Thanks
As a bit of an afterthought, has anyone got any pictures/diagrams they can post that shows how the choke cable should be connected to the carb levers. The connection on my car looks a bit crude consisting of a couple of bits of bent wire!
[ 04-03-2004: Message edited by: catfood ]</p>
They ARE a couple of pieces of bent wire. Actually a single wire bent into a V shape with a circle in the center, The main inner wire extends through the circle & is stopped with a clamp.
Each side of the V goes through a trunion on a carb linkage & is secured with a set screw. All three of the wire ends are adjustable to set the total & individual linkage pulls.
For a reason unknown to me, the rear choke operating arm is longer than the front. This results in the rear carb being less choked than the front for the same amount of cable pull. Since the design came from your side of the pond, I leave it to you do decide if it is "normal" D
[ 04-04-2004: Message edited by: Dave Russell ]</p>
Lutz Kramer Problem starting the cold engine Austin Healey 16
S BJ8 Hot Starting Problem Austin Healey 25
Mowgli81 Starting Problem Ignition coil? Dist. Cap? Austin Healey 21
D frogeye starting problem Austin Healey 2
tahoe healey starting problem Austin Healey 10
J Spitfire Hot starting problem, 78 Spitfire Triumph 7
mgbmedic Wedge Triumph TR7 Starting Problem Triumph 4
roofman Spitfire 75 spitfire starting problem Triumph 6
B TR6 TR6 starting problem Triumph 24
P Starting problem .. and a burning problem?? Austin Healey 11
C MGB Wierd starting problem - 77 mgb MG 4
R odd starting problem Spridgets 1
T Novice seeking advice on starting problem Spridgets 32
R Hard starting problem Austin Healey 2
LastDeadLast Help me with a starting problem Triumph 17
R Starting problem MG 6
R Cold Starting Problem for a BJ7 Austin Healey 4
B Healey starting problem Austin Healey 19
B Starting Problem Spridgets 6
W Starting Problem Austin Healey 4
M Intermittent starting problem Jaguar 1
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
