Starting Problem
wlivesey
I have a 1960 BT7. Battery is fully charged. I have cleaned all of the connections (except the starter button - I will get to it)and cleaned up the starter from all the crap inside - brushes seemed OK. Occasionally, the car just won't crank - the starter will "grown" and then do nothing. It can happen any time, first thing in the morning or after its warmed up. Most times I just keep pusing the starter button until it eventually scranks and starts. I have heard the starter can have a "flat spot" but I don't really eaxactly know what that means. Any suggestions or ideas?
Bill L
Bill,
I don't know yet.
What happens if you have the headlights on during the time you try to start it. If the lights dim when it fails it means something different than if they don't dim. Give it a try & see which is happening.
Sound like VD [Voltage Drop] to me. Go buy a stout #4 wire and run it from the terminal in the trunk where the ground strap attaches to the shut off switch, then run the wire under the car and attach the other end under one of the starter securing bolts. This makes a secure path for the amperage to flow not only to the starter but also back to the battery. In cold climates when cranking the engine over, which is usually slowly due to oil viscosity, some times the resistance of the body-ground is so high that the terminal voltage is not high enough to fire the coil - thus no spark. This added ground make a marked difference.
Regards, Bob
Thanks alot for the advise, guys. As you might expect, the last couple of days the car has started right up. I am driving up to the British Invasion in Stowe Vermont this weekend. I think its about a 3-4 hr drive. It will probably happen since it seems to happen more often after a long drive. I will let you all know when I get back. Thanks again for the advice
Bill
My 61 BT7 does this as well. I dissassembled the battery switch and cleaned it, and for while it was better. It is doing this again occasionally. I suspect the starter solenoid, as I had these exact same symptoms in by boat, and it turned out to be one (of two) solenoids. I think I still have the original solenoid in it.
Pete H
Lutz Kramer Problem starting the cold engine Austin Healey 16
S BJ8 Hot Starting Problem Austin Healey 25
Mowgli81 Starting Problem Ignition coil? Dist. Cap? Austin Healey 21
D frogeye starting problem Austin Healey 2
tahoe healey starting problem Austin Healey 10
J Spitfire Hot starting problem, 78 Spitfire Triumph 7
mgbmedic Wedge Triumph TR7 Starting Problem Triumph 4
roofman Spitfire 75 spitfire starting problem Triumph 6
B TR6 TR6 starting problem Triumph 24
P Starting problem .. and a burning problem?? Austin Healey 11
C MGB Wierd starting problem - 77 mgb MG 4
R odd starting problem Spridgets 1
T Novice seeking advice on starting problem Spridgets 32
R Hard starting problem Austin Healey 2
LastDeadLast Help me with a starting problem Triumph 17
R Starting problem MG 6
R Cold Starting Problem for a BJ7 Austin Healey 4
B Healey starting problem Austin Healey 19
B Starting Problem Spridgets 6
catfood Starting problem solved, but... Austin Healey 1
M Intermittent starting problem Jaguar 1
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
