Single HS4 on a 1500
bigjones
Hi folks,
I've been following this thread on the conversion but have some questions:
https://tinyurl.com/ygoj9o6
Do you elongate the holes in the carb to make it fit the existing stud pattern on the manifold? I just want to double check before I take a file to a brand new carb!
Also, on my engine at least, it is necessary to use carb vacuum to suck on that hose coming off the valve cover, otherwise there is big oil leaks. Has anybody figured this out on the HS4 - there is a tiny pipe but that must be for the vacuum advance. There is a larger hole but that has been shut off at the factory with a plug. Should I try and remove this plug and fashion some sort of pipe?
Cheers
Hey Adrian! I've been wondering where you were!
I modified the manifold on my Triumph 1300 (same basic manifold) to move the studs and not have to file the HS4. However, by all accounts of those who have done this, the easier method is to elongate the HS4 mounting holes into slots. If you are worried about messing up that new carb... and can come up with a spare manifold to modify, I can move the studs for your setup also. Remember, I'm only over in Durham.
I eventually fitted the ABD MGB needle to my HS4 and I switched to a thicker dashpot oil. The engine ran better with that arrangement. However, I learned today that the other "sick engine" symptoms I've been experiencing and blaming on the carb were a failing head gasket and some leaky intake valves. In short, I'm still a long way from being on the road!
Doug!
Many thanks for the post.
Yeah, I have not been on the forum for a while - the MG is running very nicely with no problems. Apart from the poor gas mileage (22 mpg). Hence the interest in the HS4.
I picked one up from Burlen in the UK almost a year ago - I have put off installing it because it is a thing of beauty. Now and again I take it out of the box and fondle it lovingly.
Thanks for the clarification on the mounting holes and your kind offer to move the bolts. Let me ponder that awhile.
This carb has a standard needle - I would be very surprised if it does not require some modification. But that is in the future - right now I'm trying to figure out just attaching the carb to the manifold!
Like yourself, I think I'll use a heat shield between carb and manifold and use that to attach the accelerator and choke cables - I have a beat up 1275 heat shield that I'll try to modify.
Would be nice to get it operational before the car show!
Sorry to learn of the head gasket problem - I've replaced those on the 1275 and the Triumph - takes a while but its not high tech! Best of luck!
Cheers,
Adrian
Adrian - I'm the one with the HS4 and I elongated the holes. Looking at your carb I can understand why it would hurt to hurt it. Looking at the carb you will also have to make a decision about your float. It will need to hang vertically when the carb is mounted. If you talk to Joe Curto he can tell you what float to use and will sell you one for about $45. Or, you can adapt your existing float. First off, the bolt holding the float to the carb body is not in any way connected to the fuel system, so, anything you do at that end will not make it leak. I foolishly ground the flange off the body of the carb, rotated the float vertically and tightened the bolt - still worked fine though. However, I am having the carb rebuilt even as we speak and the guy doing the work will pin it properly. What I should have done was adapt the "washer" on the float that "keys" to the flange on the body. (it will make sense when you have the float off). The only other issue was the fuel line from the float to the carb - it should be shortened slightly but I tried it and ended up with a leak so, second time I just left it and it worked fine. I love the HS4 though and would be happy to post pics when it comes back.
The float bowl assembly itself is not what sets the angle of the float bowl, it's the float bowl grommet that sandwiches itself between the float bowl and carb body, Curto will have the correct grommet to correct the float bowl angle, and they a fairly inexpensive. So no need to replace the float bowl, just the grommet.
JP and Hap,
Thanks for the info on the flange - I was just going to grind it off but getting the correct grommet would be preferable! I'll get in touch with Joe.
I'm pondering now on how to attach the choke cable - the carb has a hole in the body, below which is the choke mechanism. VB sells a "trunnion" - is that a little cup that fits in the hole and holds the outer sheath of the cable?
Cheers
Hmm,
May have that wrong on the choke cable mechanism.
Anybody know offhand how the outer choke cable is secured on a 1960's MGB?
Cheers
I don't know how they ran the choke cable on an MGB. I didn't use the boss on the carb body for the choke when I fitted the HS4 to the 1300. I made a clamping block and ran the throttle cable and choke cable parallel to each other. I can take a picture of it if you want but it may not be much help.
On the B there's an "arm" as part of the air cleaner retaining bracket with a hole for the inner cable to be secured, via a clamping bolt. The sheath does the moving of the choke mechanism (from a "socket" on the cross-linkage).
With a single carb you'll need to MacGyver up your own device, methinks.
:lol:
I'll try and post a photo or two of the relevant MGB parts. It appears you have a right side (rear) B carb... the "arm" I referred to mounts on a front one but with pix you may find a way to fettle one to work.
'smits (SWMBO) has the camera just now so it may be tomorrow before I can post anything enlightening.
Here are some photos of the hole modification that I did to put an HS4 on my 1500:
BillM
I just got a call tonight that my carb is ready - will likely pick it up on Wednesday and will post pics of the choke ASAP
??? I thought you already had the carb. Were you having it professionally rebuilt? If so (out or curiosity) by whom?
Rebuilt - Blane Hughes here in Toronto - everyone says he is the guy to go to. will let you know
BillM,
Thanks for the good photos.
Looks like you drilled out the holes instead of filing, is that right?
Does your accelerator cable pull downwards?
How did you hook up your choke cable?
Cheers
Remember Adrian... I do have a mill. We'd just need to make a fixture to bolt the intake side to to hold it in the vise.
Doug,
Many thanks for the offer - I'll probably just go ahead and file elongations to make it fit on the studs.
Do you think we will need the MBG spacer block?
(I'm getting up a list of things)
Cheers!
Adrian
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
RobSelina Single SU HS4 swap on a 1500 Spridgets 2
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
C LCB header with 1500 single carb inlet manifold Spridgets 1
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
shadowfever Single SU on Spridget Spridgets 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K WTD Single SU Manifold for AH Sprite Spridgets 0
R 1275 engine with SU HIF single carb Spridgets 9
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
drooartz Single stage vs base/clear Spridgets 29
M TR2/3/3A Single brake light modifcation Triumph 2
W Single Minator wheel available Spridgets 3
N DCOE double vs. single choke theory Spridgets 11
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
T building a single tower Sprite storage lift? Spridgets 21
J Bugeye single piece top frame same as two-piece? Spridgets 4
B Spitfire big bearing snap rings on Spit single rail Triumph 0
B Spitfire That Spitfire single rail gearbox again Triumph 2
N Convert BJ8 exhaust to single silencer Austin Healey 6
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
L Two screw or single bolt side view mirrors? Austin Healey 8
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
Ofcalipka Zienith single carb problems. Spridgets 34
Ofcalipka Zenith single carb problems MG 62
T Triumph Spifire - single rail gearbox sychro Triumph 0
M Help with single SU on midget Spridgets 19
bighealeysource single 12 volt battery conversion on a 1954 BN1 Austin Healey 9
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
dklawson Spitfire Spitfire - Single-Rail Gearbox Frustration !!! Triumph 20
dklawson Spitfire Spitfire Gearbox Swap - 3-Rail to Single [Parts?] Triumph 2
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
58Custom Anybody have schematic for single transistor tach? Spridgets 6
B single stage PPGpaint for Healey Austin Healey 15
beaulieu XK 120 Batteries - single 12v or pair of 6v ? Jaguar 7
T Single rail transmission Triumph 1
DART Huffaker "single hoop" MGB Racing 1
C Intake for single SU Spridgets 10
Aldwyn Single Headrest? Triumph 7
Randy Forbes Single [double jet] windscreen washer questions... Austin Healey 7
