single 12 volt battery conversion on a 1954 BN1
bighealeysource
Bronze
Hey all,
I recently purchased a 54 BN1 that had the twin 6 volt batteries
converted over to a single 12 volt battery put in the trunk.
In the process of restoring the interior and trunk and was
wondering if anyone knew if the standard 12 volt Healey
battery would fit in where one of the 6 volt units sat ?
Know I can unhook it and check it out but thought I might get
the opinions of someone out there who might own a BN1 or BN2.
My main concern would be the fit of the 12 volt unit from
a height issue and suspension travel of the rear end unit.
Thanks,
Mike
I was able to put a single 12VDC Optima battery in the place of one (1) of the 6VDC batteries originally fitted to my BN6 (100/6 2-seater).
No issues at all, in my case.
I think a standard battery will fit in one of the trays with a little mod to the tray, I had a Interstate MT24 (from memory, but pretty sure that is correct) in mine. Less weight and less money, plus probably better cranking amps than the dual 6 voltss.
Re: single 12 volt battery conversion on a 1954 BN
I have two 12V batteries connected in parallel, still positive earth. Fits nicely on the two trays and works very well. The car is locked away for the winter so I don't have/remember the outer dimensions nor the ampere.
Georg
oslo100,
I would be interested to find out if they fit the original trays, as the only ones I can source that do fit are expensive sealed ones ones (about $300 each!)
Thanks y'all for your help with this question. Guess I'll have to break down
and just take the battery out of the trunk and see how it fits or go with the
12V Optima.
Regards,
Mike
A friend is using 2 12 volt garden tractor batteries in his XK120. I have a Miata battery in my BN1 but I had to notch the tray to get it to fit.
Marv J
Hi zblu,
They are the sealed (kalsium)type (and apparently maintenance-free too), but are only about 90USD each. Sadly I can't provide you with more info before approx. april. I look however forward to being able to!
Georg
Hello bighealeysource,
I have a single 12 volt battery in my BN7 which came from Sears(the battery and not the BN7 that is).
The last time I looked at the Sears website they had dimentions of the batteries on there.
I don't remember if there was a difference between the space in the battery compartments of the BN1 and BN7.
Regards,
bundyrum.
M Single 12 volt battery conversion MG 2
C LCB header with 1500 single carb inlet manifold Spridgets 1
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
shadowfever Single SU on Spridget Spridgets 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K WTD Single SU Manifold for AH Sprite Spridgets 0
R 1275 engine with SU HIF single carb Spridgets 9
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
drooartz Single stage vs base/clear Spridgets 29
M TR2/3/3A Single brake light modifcation Triumph 2
W Single Minator wheel available Spridgets 3
N DCOE double vs. single choke theory Spridgets 11
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
T building a single tower Sprite storage lift? Spridgets 21
J Bugeye single piece top frame same as two-piece? Spridgets 4
B Spitfire big bearing snap rings on Spit single rail Triumph 0
B Spitfire That Spitfire single rail gearbox again Triumph 2
N Convert BJ8 exhaust to single silencer Austin Healey 6
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
bigjones Single HS4 on a 1500 Spridgets 25
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
L Two screw or single bolt side view mirrors? Austin Healey 8
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
Ofcalipka Zienith single carb problems. Spridgets 34
Ofcalipka Zenith single carb problems MG 63
T Triumph Spifire - single rail gearbox sychro Triumph 0
M Help with single SU on midget Spridgets 19
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
dklawson Spitfire Spitfire - Single-Rail Gearbox Frustration !!! Triumph 20
dklawson Spitfire Spitfire Gearbox Swap - 3-Rail to Single [Parts?] Triumph 2
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
58Custom Anybody have schematic for single transistor tach? Spridgets 6
B single stage PPGpaint for Healey Austin Healey 15
beaulieu XK 120 Batteries - single 12v or pair of 6v ? Jaguar 7
T Single rail transmission Triumph 1
DART Huffaker "single hoop" MGB Racing 1
C Intake for single SU Spridgets 10
Aldwyn Single Headrest? Triumph 7
Randy Forbes Single [double jet] windscreen washer questions... Austin Healey 7
mgbmedic Single Zenith Carb- Results MG 1
