Possible Midget purchase - advice needed
Robby
I am considering adding a Midget project to my MG garage. I have found a 74 arched wheel Midget that runs good but still needs quite a bit of work. It most likely needs a driver's side floor pan and a hood as well as a new top, carpet and of course paint after repairing everything. Body is pretty good otherwise. It is drivable car as it sits but would need some stuff before putting it on the road such as fixing blinkers, speedometer cable and gas gauge rewired.
Any thoughts on a rough order estimate of value? I know you can't get specific but just an idea of value. I think I can get it for around $700-750 but not sure.
Tha
If that's all it needs, has no hidden rust in the usual places, hasn't been wrecked, drives and stops, GO FOR IT!
Floor pans by them self are easy. In fact can be glued in. Yea I know but that is how new cars are assembled.
Check for bondo in the rocker and the cowl (b/w door and front fender). I've seen them ate up by the rear spring perches. Look it over well, then do it again. Check for crumpled or cut/welded panels in the trunk and under the hood. is there another car that's clean you can look at to see what it's supposed to look like?
If the car is good ~ $700 isn't bad at all.
Hello,you said it runs and if you can drive it around the neighborhood some to give you an idea of the tranny condition and brakes.
Not to be a wet blanket, but there is one thing to think about: If you buy a cheap runner for $700 that needs a number of things, you can easily end up spending more than you would if you bought a $3,000 runner to start with that is already in better shape. I have done this a number of times. Don't know why I have never learned... Jim
+1 - if you want a runner, there should be any number of decent cars that far south.
If it runs, the price is not too bad. If you're handy, you can make it into a decent "driver" for modest money (make sure brakes and front end are decent).
I also see nothing wrong with spending a lot of money to make it real nice......if that's your thing and you can afford it.
There's worse ways to spend your time.
You may not make a profit on it (to me, the "profit" is the pleasurable time working on it and driving it and is not measured by return on investment)
Anyway, here's a similar example from me.
I bought this RWA Midget last August for $250. I had been informally looking in craigslist for a while before I found it in a small ad with no pictures or price.
I was actually looking for a parts car to donate a spare 1275 engine for my Austin A35 racer project. This '73 was 100% complete and would probably have run with a decent battery, but I never even tried. I've already pulled the 1275 engine from this car and begun the rebuild to race specs, but the car itself is really solid and it's a shame to chop it up.
So, I am cleaning it up and have just finished (mostly) doing a quick re-paint (same colour red). I have a spare, stock 948 that will go in it.
I have tons of other spares including tires, a new top and so forth, so this will be a "cheapy" car that I will slap together (the most expensive part will be new brake parts). I'll put "classic" plates on it and I doubt it will travel more than 500 miles a year, but it's sort of fun to have an "accidental" car. Eventually, I'll probably pass it off to one of my kids or my brothers.
I appreciate the input but after talking with the owner some more and giving it more thought, I decided to pass on this one. He later told me that the transmission was making some noise (more than usual in a Midget) so decided it wasn't worth what I could buy it for.
Robby
Robby
Midgets are like buses - another one will always come by. (good call IMHO)
bluemiata90 MIATA 5 SPEED TRANS INTO A 1974 MIDGET, POSSIBLE?? Spridgets 2
F Chrome bumpers and grill for 76 Midget. Possible? Spridgets 14
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Rut MGA Possible purchase MG 10
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
smaceng TR6 Possible Purchase of a TR6 Triumph 21
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
