One thing Triumph DID get right...
G
So I took the dog out for a drive in the TR6 last night. (She likes convertibles, what can I say).
A few miles down the road the speedometer goes dead. Aargh... Visions of hours of work dismantling the dash to get at the speedo cable attachment ruined the rest of the drive (for me at least - the dog was still happy).
It turns out that replacement is a snap. Nothing at all to dismantle as it just unscrews from the back, and you can reach up underneath to get to it. The hardest part of the job will be waiting for the cable. (It is the cable btw - I checked when I got back).
For that I can almost (but not quite) forgive them Lucas electrics...
When you own other sports and classic cars, you actually begin to appreciate how easy it is to work on a Triumph. And for as much stink that is made over Lucas electrics, they are no more trouble-prone (and much easier to fix) than C3 Corvettes (and certainly any Corvette 1984 and newer!)
And look at it this way-- you could have a Porsche 911 and have to drop the engine and transmission to fix the right-angle drive for the speedo! /ubbthreads/images/graemlins/wink.gif I also replaced a speedo cable in my 911 a few years ago, and found it to be a total pain, since it snakes through the interior of the car.
TRs might not be the most luxurious cars in the world, but they are usually easy to fix.
This may be too late for you, but FYI -- replacement cables are usually available locally for about 10 bucks. Any speedometer shop can take your old cable housing and make a new cable to fit it. Takes them about 3 minutes -- I just have them do it while I wait.
An advantage (other than price) is that (at least on TR3s & 4s) if you are still using the original housing you can keep the original look (many replacement cables are black, TRF has one that is silver/gray), the originals were white (sort of yellowish white after 40 or 50 years).
Mine's already black, so it looks like it must have been replaced; it doesn't matter to me that much - the oil leaks would turn it black anyway /ubbthreads/images/graemlins/smile.gif
Also I have no clue where a speedo shop would be in my area - I can't even find someone who wants to work on carbs locally. Thanks for the info though...
The cable is spiral wound and it must have the correct hand wind to it or you will have troubles with it. Check which way the cable rotates and make sure that it winds "tighter" as it operates. The usual suspects do not know this fact any more.
mezy A thing of beauty Other British Cars 3
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
S TR4/4A What is this thing? Triumph 3
L TR6 Is there any such thing for a TR6 ? Triumph 9
Pythias For Sale The Red Thing... Make Offer.. Spridgets Classified 0
60TR3A What's The Weirdest Thing Anyone Ever Said or Asked You About Your Car? Austin Healey 28
J Funniest thing you found working on your car Austin Healey 32
AN5Sprite "Does this thing have airbags?" Spridgets 22
DrEntropy MGB A little thing MG 4
ObiRichKanobi These cars do the damnedest thing... Triumph 12
R Does this thing come off? Spridgets 5
Boink Tonneau Covers - that flappy thing - what is it? Spridgets 17
Mickey Richaud Just the Thing... Other British Cars 21
lbc_newbie Closest thing to a West Coast deal!! Spridgets 4
TR6oldtimer The thing I forgot to do Triumph 2
Brosky TR8 Visors NLA, so I did the next best thing Restoration & Tools 2
BobbyD TRafficator Signal LED Buzzer Thing Triumph 7
mikecyc72usa It's a good thing, right? MG 3
tinman58 Second thing to check Triumph 14
1 What is this thing? MG 10
G One thing after another MG 30
TR4A_IRS TR4/4A TR4 Hardtop - Is there such a thing? Triumph 7
T Post-War Other No such thing as a 1 hour job on a Herald Triumph 8
pjsmetana Fuel Filter, anyone got a part # for this thing? Triumph 11
T What do you think - good thing I pulled them? Triumph 6
T Wedge TR7/8 doing it's thing in this clip Triumph 3
T I think I did a dumb thing Spridgets 14
C turn signal bulb type thing Spridgets 4
P weird thing with midget clutch pedal Spridgets 3
smaceng Help me find the steering thing! Spridgets 7
jdubois Finally, this thing is starting to run ok! Triumph 7
D Ready to shoot the thing II--an Latest Spridgets 7
D Ready to shoot the thing! Long story please help! Spridgets 10
T It's a small thing, but WOW. Triumph 25
jhorton3 If It's Not One Thing It's Another Spridgets 3
jlaird This may be just the thing for someone. Triumph 1
regularman The bad thing about having a high rear gear Spridgets 13
G What is this thing !?!?!?!?!?!? Spridgets 6
Sarastro Was this a smart thing to do? Other Cars 18
regularman Still trying to figure this overheating thing out. Spridgets 35
Tinkerman Did a REAL Dumb Thing!!!! Triumph 7
healeyboz Is there such a thing as Spridgets 4
T Hap, what is that thing...? MG 14
vping Last thing on my OD problems. MG 5
wkilleffer What causes heat soak, and is it a bad thing? MG 16
MTribe Is sound deadening on floor pans a good thing? Triumph 24
