Funniest thing you found working on your car
jcsb
Well since I'm going through a complete tear down I am running into some interesting things, but this really was unusual. After taking the dash off I found a spark plug staring at me. Looking closer I see where the PO used it and a hose clamp to block off the heater hose. Interesting technique. :highly_amused:
John
Healey Nut
Cardboard box covered over with fibeglass mat and roofing tar to patch the main frame rails ........Needless to say it got fixed ......correctly
judow
Darth Vader - R.I.P
As Agatha was in many pieces we did find a Manila envelope in the boot. You should know she was up to her axle in Miami sludge a/k/a swamp in a junkyard. In the envelope were every bill of sale from her first transfer to the junkyard. Sure saved us a lot of problems when it came to register her in New Mexico. The next to last transfer was from the wife of her deceased husband to their priest in Miami.. It was he who was responsible for her junkyard resting place. That was an interesting and fortuitous find.
oxford
Interesting but not Healey: in the fuel tank of my MGA I found a coin. My son, who is restoring a 1927 Humber also found a coin in the fuel tank. Coincidence? Or was this considered to be good luck? Or perhaps a way of stopping sludge from settling in the bottom? Or maybe people were clumsy with coins then? Guess I'll never know. I put the coin back in the MGA. I sort of like that. Part of the originality. The Healey has a new fuel tank so I'd better find a coin to put in!
Matthew
pan
I once removed a door from my wife's Sprite (can't remember why) and when I turned the door on its side a penny fell out of the door pocket. Australia converted to Dollars & Cents in February, 1966 so this penny had been rattling around in there for quite a while!
Once while tinkering with my 100 I dropped a spanner and it landed in the bottom of the front 'guard (fender to you blokes). I was groping around in there to retrieve the wayward Sidchrome and found my oil filler cap! I'd lost it years earlier when I was careless when replacing it in the driveway of a service station. I had heard it land on the ground but try as I might I just couldn't find it! I had to use a temporary cap until I could obtain a proper replacement but, turns out it was in the car all the time!
Speaking of finding little treasures in the door pocket, in 1969 Brian Dermot, while dismantling NOJ 392 in preparation for restoration, found in the door Geoff Healey's note book from LeMans 1953!
kkaa
Not a Healey, but a Ford Mustang. Pulled the carpet in the passenger side foot well, looked close, peeled back a layer of fiberglass and found a perfect Waffle Iron skillet welded in place!!! HA!!
Jerry
Found a half inch bolt on the front bumper bar. It was 12 inches long. Not attached, just sticking there. We could not figure out why it was used or what it was used for.
Jerry
When I flipped my Healey chassis upside down, a couple of 1/4" drive sockets rolled out of the black hole (LH front chassis leg diagonal support). They were both rusty, maybe a 5/16" and perhaps 7/16" but niether was worth saving; no telling how long they'd been there.
AH100M
I had this fantasy as a kid of being able to go into an auto parts store and ask for a set of spark plugs for my car. When the guy behind the counter would ask "four, six or eight?" I would smugly say "Twelve."
I don't think I could ask for "Seven".
Editor_Reid
Platinum
I don't know if it's "funny" exactly, but it used to be quite consistent that my friends and I would find the following items under the carpet in used sports cars:
A bottle opener.
A comb.
A penny.
I don't know why we never found a nickel, dime or quarter, but the bottle opener and comb always led me to believe that the car had seen lots of use in someone's dating life.
LarryK
I bought a 78 1500 Spitfire for a turn around car. Drove it for a couple weeks and then stripped top to replace and remove some dings and to put on new tires. As I was cleaning the car I found 4 reefers crammed between the seats and the tranny tunnel. Surprise!! Glad I had not been pulled over. They were wet and soggy as top had leaked.
bob hughes
I found a spare set of keys taped to the underside of the square heater duct leading to the flaps just above your feet. One key was a dead fit for the ignition with matching numbers, the other key had a different number but still started the car, neither keys locked the boot ( trunk).
Assorted nuts and bolts from the black holes in the engine compartment
And a friend of mine found a .22 rifle round in his whilst welding it up, the round exploded with the heat but fortunately nobody was hurt.
:cheers:
Bob
The trip reset gear from the speedo under the drivers seat. Speedo wasn't apart but when opened up to refinish the case, that gear was indeed missing form the end of the shaft.
Griz
I bought my Bugeye in 1967. From the first that I owned it the gas gauge would never read more than 3/4 full. I just figured that "that's the way it is". While doing a full restoration in 2004 I pulled the gas tank and the sending unit. Wrapped around the sending unit float arm was a woman's scarf! Only thing I can figure is that someone lost the gas cap sometime in the car's dim past and stuffed a scarf in the hole to keep gas from sloshing out.
Griz
pkmh
When I purchased my first Healey, I was able to start it and let it idle but couldn't drive it at that time for I had no working brakes. As I was going about tuning it up and becoming familiar with it, I noticed how there was a compression tester extension attached between one spark plug and a ignition wire. Obviously, someone was in the process of testing the compression but never removed the extender. Amazing how revving and idling never gave a misfire or clue of something ever running amiss. And because of that, I was worried there was some legitimate purpose for that being there. Gladly, there wasn't but noticed no difference in idling before or after. Guess that fooled the previous owner, too, obviously.
roscoe
No comedy during my restoration although I did get boxes and boxes of little bits which, being a novice to the Austin Healey, I had to assume were for the BN2. Of course they were British bits to be sure but they don't fit on this car. Oh, the wasted hours. I do have a suggestion for the spark plug that was in the heater hose. Leave it there, attach a wire to it and run the wire into the recesses of the instrument panel, attached to nothing. This is not for you. This is for the person who inherits your Healey to figure out.
MikeAH100M
My father-in-law bought an early 80's Chrysler Cordoba (yes, with rich Corinthian leather) that made all kinds of noise in the rear on braking and turning. After checking everything, finally removed the rear quarter panel only to find empty beer cans, wrenches and an air-driven impact hammer. How's that for an homage to the auto workers in the 80's! I think it was same year that Chrysler recalled more of these cars than they made.
mezy A thing of beauty Other British Cars 3
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
S TR4/4A What is this thing? Triumph 3
L TR6 Is there any such thing for a TR6 ? Triumph 9
Pythias For Sale The Red Thing... Make Offer.. Spridgets Classified 0
60TR3A What's The Weirdest Thing Anyone Ever Said or Asked You About Your Car? Austin Healey 28
AN5Sprite "Does this thing have airbags?" Spridgets 22
DrEntropy MGB A little thing MG 4
ObiRichKanobi These cars do the damnedest thing... Triumph 12
R Does this thing come off? Spridgets 5
Boink Tonneau Covers - that flappy thing - what is it? Spridgets 17
Mickey Richaud Just the Thing... Other British Cars 21
lbc_newbie Closest thing to a West Coast deal!! Spridgets 4
TR6oldtimer The thing I forgot to do Triumph 2
Brosky TR8 Visors NLA, so I did the next best thing Restoration & Tools 2
BobbyD TRafficator Signal LED Buzzer Thing Triumph 7
mikecyc72usa It's a good thing, right? MG 3
tinman58 Second thing to check Triumph 14
1 What is this thing? MG 10
G One thing after another MG 30
TR4A_IRS TR4/4A TR4 Hardtop - Is there such a thing? Triumph 7
T Post-War Other No such thing as a 1 hour job on a Herald Triumph 8
pjsmetana Fuel Filter, anyone got a part # for this thing? Triumph 11
T What do you think - good thing I pulled them? Triumph 6
T Wedge TR7/8 doing it's thing in this clip Triumph 3
T I think I did a dumb thing Spridgets 14
C turn signal bulb type thing Spridgets 4
P weird thing with midget clutch pedal Spridgets 3
smaceng Help me find the steering thing! Spridgets 7
jdubois Finally, this thing is starting to run ok! Triumph 7
D Ready to shoot the thing II--an Latest Spridgets 7
D Ready to shoot the thing! Long story please help! Spridgets 10
T It's a small thing, but WOW. Triumph 25
jhorton3 If It's Not One Thing It's Another Spridgets 3
jlaird This may be just the thing for someone. Triumph 1
regularman The bad thing about having a high rear gear Spridgets 13
G What is this thing !?!?!?!?!?!? Spridgets 6
Sarastro Was this a smart thing to do? Other Cars 18
regularman Still trying to figure this overheating thing out. Spridgets 35
Tinkerman Did a REAL Dumb Thing!!!! Triumph 7
healeyboz Is there such a thing as Spridgets 4
T Hap, what is that thing...? MG 14
vping Last thing on my OD problems. MG 5
wkilleffer What causes heat soak, and is it a bad thing? MG 16
MTribe Is sound deadening on floor pans a good thing? Triumph 24
B What is this thing?? Spridgets 37
