Did a REAL Dumb Thing!!!!
Tinkerman
Yep I just screwed up big time. I did what several of you suggested I be careful about and broke through the block with too long a bolt for the water pump. I was torquing every thing down when it happened!
So, what are my options?
I know that one option is to start over with a good block, but I really, REALLY don't want to do that.
So any help please, with ideas.
Thanks, Tinkerman the dumb
Stig
Over the years I've turned screwing up into an artform. As a result I've gotten pretty good at unusual repairs. If you simply poked a hole at the bottom of the threaded area, it can be repaired by drilling out the hole and cutting new threads that will accept a sealed threaded insert.
Flinkly
in all seriousness, i'd call your local machine shop that has been around for some time. so far, my local machine shop has repaired at least 2 really big screw ups for me. saved me about 200 dollars in buying replacement parts and cost me only 20 bucks to fix my mistakes. they seem to know secrets about fixing all kinds of problems, and i'm sure have seen every problem you can think of.
at least call them for opinions and solutions cause there is more than one way to skin a cat.
PeterK
Quick, smash something repeatedly with a BFH. And shout D'OH! Make you feel any better?
On the TR 4 cylinder block, there are several holes that are threaded all the way through. Just apply a good sealant like Permatex non-hardening to the threads (of the proper length bolt) and it should seal up OK. I think....
Mickey Richaud
That's what I was thinking, as well. There is at least one of the bolts that secure the water pump housing to the front of the TR8 block, whose threads go through to the water passage. No leaks here. Just be sure you've cleaned out the metal bits first!
Tinkerman
Tinkerman
Yep same thing that the engine mechanic that did the machining on my engine said. Sealant is the answer. Phew, do I feel better. He uses Permatex ultra copper high temp silicone. Have a tube in my possesion as I type. He said that it isn't all that unusual of a situation.
My thanks to all of you for the suggestions. Peter, I keep a BFH around just for those "special" occasions. I have a very stout table and a large chunk of railroad tie that I'm able to vent on. My very understanding wife knows when those sounds are being made that I'm probably not working on a part of some type or another.
By the way Peter, I sent you a PM awhile back, did you ever get it?
Regards, Tinkerman
PeterK
Yes I did Dick; thought I replied but I guess not. Small world, huh?
Glad the clip worked for you.
I remember Fred Flintstone saying razzlefrazzlepazzzmerazz or something like that when he needed to vent. So I use that expletive too (with my BFH or whatever is closest) when needed.
mailbox
I use totally different words (NONE of which can be posted here) at a MUCH louder volume and tend to throw things that shouldn't be thrown at things that shouldn't be thrown at (wrench at car, carb at dog, etc.....).
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
Y MGB How did become such a mess up???? MG 2
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
V MGB Mystery fastener from '66. Did I miss something? MG 6
mezy Heres one i did. Other Cars 9
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
jlaird MGB Don't post like I did 10 years ago. MG 7
AngliaGT MGB What Did You Do on Your MGB Today? MG 6
JPSmit Honey, did you hear that clunk? Other British Cars 0
B TR4/4A What did I do wrong? Triumph 19
Elva164 Finally did another onboard video! Racing 4
Jim_Gruber When did Mini’s get so expensive Spridgets 20
J TR4/4A Did my own carpet Triumph 16
Jim_Gruber So what did I do wrong here with Bugsy. Spridgets 2
Jim_Gruber Did my clutch just bleed itself? Spridgets 11
warwick-steve Where did the smell go? Austin Healey 11
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
kennypinkerton MGB Things I remember that I did to my MGB... MG 4
TomMull TR2/3/3A Did sombody just get lucky? Triumph 4
PC Morgan fans - how did I miss this? Other British Cars 2
JPSmit Hyundai Stellar - when last did you see one? Other Cars 6
longbridgehealey When did you buy your first LBC, and what was it? Spridgets 46
H 1925 Rolls Phantom I "round door Rolls" in Petersen collection: what did it sell for? Other British Cars 5
H Joan Baez flat floor '61 roadster, what did the Feds sell it for at auction? Jaguar 0
nicko Did you know....... Austin Healey 15
K General Tech Why did MGB's come with oil coolers but Triumph's didn't? Triumph 17
R Where did it go? A who-done-it mystery! Austin Healey 18
Rut TR4/4A I did it again... Triumph 27
PC didn't spot a 911 or a Javelin but did see a station wagon Spotted 1
T TR4/4A Access to a professional sandblasting set up - why the heck did I wait so long... Triumph 4
Editor_Reid FYI re "What Did You Do On Your Austin Healey Today?" Austin Healey 0
CessnaTPA What Did You Do On Your Austin Healey Today? Austin Healey 98
2billydavies TR2/3/3A just removed the pistons/sleeves... can't believe she ran as well as she did! Triumph 6
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
H Michelotti one off body on an E-type? What year chassis and what shop did the work? Jaguar 0
C The "Lightweight" Jaguar E-Type.....why did they only make six?? Jaguar 2
D Challenger 2.5 did 419 one way at the flats today. Racing 2
Gliderman8 TR6 Did one of you guys lose this? Triumph 10
P General TR What vehicle did this windscreen come from? Triumph 2
tinman58 TR5/TR250 Did I screw up? Triumph 4
glemon General TR What Did You Do to Your Triumph Today? Triumph 119
Moseso TR2/3/3A PeterK, or others -- How did you mount your BMW fan on the TRactor motor? Triumph 3
trrdster2000 Off Topic What did you expect? Triumph 6
58Custom General MG What wheels did I buy? MG 8
R How long did it take to restore your car? Austin Healey 18
Rut How did you come to own a Bugeye? Spridgets 17
69sprite New trailer - Did I miss the mark? Spridgets 8
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
Jim_Newman Where did I go wrong? Austin Healey 37
