I think I did a dumb thing
tdskip
So the Bugeye fired right up today when I got out to the hanger, but I just couldn't leave well enough alone. Actually, she was not running right and was "breaking up" at higher RPM. So I went to dynamically time her, she is a 1098 btw, and the timing marks are sketchy at best so I did it by ear and that helped some but she was still breaking up at higher RPM. Given that he has a newly rebuild distributor from Jeff with a positive earth Pertonix I figure the coil might be at fault. She is a positive earth car.
When I went to remove the old no-name coil was pretty hot. It had 12v use with external ballasted resistor stamped on it. I swapped in a new Lucas Sport Coil and she started briefly, ran really smooth and then died. I didn't change any of the wiring during any of this.
<span style="font-weight: bold">My wiring is</span>
Coil + side to ground
Black line to A2 ( I think it is A2, it is hot) screw in at the fuse block. This is supposed to be run to ignition switch but my ignition switch is hosed.
Black and white to - side of the coil
When connect sport coil seemed to run better with less breaking up but quit after a couple seconds
Now I have power/spark on the lead going to distributor, no spark at plugs.
My hunch is that I burned out the Pertronix unit. What do you think?
jvandyke
Did you leave the ignition on for a while but not running? That's bad for Pertronix I've read here. I put in a Crane Cams XR700 a few weeks ago and it's working slick....so far.
T
tdskip
Thanks for pointing that out.
I did while testing to see if I had spark at the coil and spark plugs, but not for long. Less than a minute at any one time at the max. Even in that short time period the coil got noticably warm.
T
tdskip
I did connect it exactly as shown, and had the car running based on the diagram below. The only thing that changes is that is swapped out the coil the car came with for a Lucas Sport Coil, and that is when the spark at the plug wires went away.... Again, it did run for a very brief time period with the Lucas before cutting out.
Pythias
Is the Lucas Sport Coil a 3 OHM coil? Both Pertronix and Crane specify one. If not, there's your problem.
Sarastro
If it's not a three-ohm coil, and Pertronix specifies one, you can add a ballast resistor to bring it up to the 3-4 ohm range. It's possible that running the Pertronix without enough resistance in front of it could damage it. Only way to tell is to add the resistor, or the right coil, and try again.
Pythias
If it wasn't, the unit is shot already, but now it would be known what to do to remedy the situation.
T
tdskip
Thanks guys. Bill - I think you nailed the problem.
The coil I used, once I cleaned all the gunk off it, looks like this.
I haven't tested the coil to see if it is a 1.5 or 3 OHM coil, but is clearly says "use with external resistor". So it appears I did correctly connect the unit but that the coil was wrong.
Going forward is a Lucas Sport Coil an OK choice with these units or is there a coil you all recommend?
Pythias
When I installed the Pertronix, I bought a matching Pertronix coil. I've since switched to the Crane 700, but kept the coil.
T
tdskip
Hey guy, to close this thread out and hopefully pass something along that will help someone else I fixed this today.
I fixed it by - wait for it - following the instructions. I had power going to the - side of the coil from an always on source instead of only having the single white/black wire coming from the power source.
I still manged to nearly destroy the unit, I think as evidenced by the crinkled decal on the unit, but I have good spark at the plugs now.
jlaird
Sad, but happy you found it.
bgbassplyr
When all else fails, then I read the instructions.
T
tdskip
Sad = sad looking ignitor?
or
Sad = as in "Man, is his lack of wiring ability really sad or what"?
LOL at the later Jack, and well deserved.
In my defense, the wiring on this car is really hacked, and that is how it was wired previously, but I still should have caught it.
jlaird
Sad, as in I feel your pain.
Tinkerman Did a REAL Dumb Thing!!!! Triumph 7
walshja OK, I did something dumb Spridgets 24
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
Y MGB How did become such a mess up???? MG 2
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
V MGB Mystery fastener from '66. Did I miss something? MG 6
mezy Heres one i did. Other Cars 9
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
jlaird MGB Don't post like I did 10 years ago. MG 7
AngliaGT MGB What Did You Do on Your MGB Today? MG 6
JPSmit Honey, did you hear that clunk? Other British Cars 0
B TR4/4A What did I do wrong? Triumph 19
Elva164 Finally did another onboard video! Racing 4
Jim_Gruber When did Mini’s get so expensive Spridgets 20
J TR4/4A Did my own carpet Triumph 16
Jim_Gruber So what did I do wrong here with Bugsy. Spridgets 2
Jim_Gruber Did my clutch just bleed itself? Spridgets 11
warwick-steve Where did the smell go? Austin Healey 11
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
kennypinkerton MGB Things I remember that I did to my MGB... MG 4
TomMull TR2/3/3A Did sombody just get lucky? Triumph 4
PC Morgan fans - how did I miss this? Other British Cars 2
JPSmit Hyundai Stellar - when last did you see one? Other Cars 6
longbridgehealey When did you buy your first LBC, and what was it? Spridgets 46
H 1925 Rolls Phantom I "round door Rolls" in Petersen collection: what did it sell for? Other British Cars 5
H Joan Baez flat floor '61 roadster, what did the Feds sell it for at auction? Jaguar 0
nicko Did you know....... Austin Healey 15
K General Tech Why did MGB's come with oil coolers but Triumph's didn't? Triumph 17
R Where did it go? A who-done-it mystery! Austin Healey 18
Rut TR4/4A I did it again... Triumph 27
PC didn't spot a 911 or a Javelin but did see a station wagon Spotted 1
T TR4/4A Access to a professional sandblasting set up - why the heck did I wait so long... Triumph 4
Editor_Reid FYI re "What Did You Do On Your Austin Healey Today?" Austin Healey 0
CessnaTPA What Did You Do On Your Austin Healey Today? Austin Healey 98
2billydavies TR2/3/3A just removed the pistons/sleeves... can't believe she ran as well as she did! Triumph 6
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
H Michelotti one off body on an E-type? What year chassis and what shop did the work? Jaguar 0
C The "Lightweight" Jaguar E-Type.....why did they only make six?? Jaguar 2
D Challenger 2.5 did 419 one way at the flats today. Racing 2
Gliderman8 TR6 Did one of you guys lose this? Triumph 10
P General TR What vehicle did this windscreen come from? Triumph 2
tinman58 TR5/TR250 Did I screw up? Triumph 4
glemon General TR What Did You Do to Your Triumph Today? Triumph 119
Moseso TR2/3/3A PeterK, or others -- How did you mount your BMW fan on the TRactor motor? Triumph 3
trrdster2000 Off Topic What did you expect? Triumph 6
58Custom General MG What wheels did I buy? MG 8
R How long did it take to restore your car? Austin Healey 18
Rut How did you come to own a Bugeye? Spridgets 17
69sprite New trailer - Did I miss the mark? Spridgets 8
