Finally, this thing is starting to run ok!
jdubois
Some of you may remember that I was having trouble getting my TR3A to stay running after many months of storage.
Well, after cleaning the fuel filter mesh, replacing the front float chamber cover due to stripped threads for the valve body, (then replacing the starter solenoid which happily fell apart on me while I was trying to fix the fuel problem), replacing the plugs that kept fouling with hotter ones, syncing the carbs, re-adjusting the mixture with my trusty colortune, adjusting the points, and then replacing the entire clutch hydraulics (which was almost completely shot), I was finally able to take her out for a bit of a drive today.
She still hesitated a bit on acceleration while warming up, both with the choke halfway out and all the way in, and she occasionally didn't want to idle when coming off of hard throttle unless I blipped the throttle again before she died, but other than that she pulled smooth and strong, and I was able to actually enjoy her for a short 15 mile drive.
So I'm getting there! Thankfully, the Spit has been a rock while I was getting the TR3A fixed, so I wasn't without a Triumph. I hope that she can't smell the TR3A on me now!
Ta muchly to those of you who gave me suggestions that led me to the bad float bowl cover, which was clearly the main problem.
DougF
That's great news. Take it for a good half hour drive and then pull #1 and #4 plugs to see how they are burning.
jdubois
jdubois
It probably wasn't long enough a drive, but I pulled the plugs anyway when I got home. They had a bit of what looked like white ash deposit on them, but otherwise they looked good.
Andrew Mace
If they're really whitish, that's not a good thing, as it usually indicates lean running...and you do not want to run too lean for too long. Years ago, I ruined a very nice B-18 Volvo engine: I'd ignored the whitish plugs/lean running...until I burned a hole in a piston in such a spot that the cylinder wall got badly scored. :frown:
NutmegCT
Congrats on the "maiden voyage". I remember well my first successful drive, after Paul (Brosky) stopped by and helped diagnose a failing starter.
The drive wasn't perfect of course, but just getting the engine going (*before* I even started fixing the whacky "choke" jet system), putting it in gear, and sliding out onto Rt 44 and driving a few miles sure did feel great.
Minor detail that the top was off, and it was still about 30° in February. But it was fun!
Best wishes to you for many more miles!
Tom
jdubois
jdubois
I'll put the colortune back on and recheck the mixture. I'm just happy they're not dead black with soot like they had been!
mctriumph TR2/3/3A Finally painted the 63 3b Triumph 14
J TR2/3/3A TR3A Finally on the Road! Triumph 6
AngliaGT Finally - A (Mostly) True craigslist Ad Other Cars 0
Grantura_MKI Pre-War Finally arrived. MG 7
HealeyPassion Finally, paint on chassis Austin Healey 17
Lou E Finally a Bugeye of my very own Spridgets 41
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
Bayless A Sprite gets some paint finally Spridgets 2
EricJNewman MGB Weird Brake issue finally solved. MG 1
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
J Shroud Painting ["Finally done with these"] Austin Healey 3
Rhodyspit75 Finally on the road Spridgets 7
AngliaGT MGB FINALLY Got the Engine Out MG 5
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Basil I finally joined Jaguar 4
J General TR Finally on the road Triumph 1
Bayless More Sprite progress finally Spridgets 23
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
Bayless Progress finally begins Spridgets 5
tinman58 General TR Finally almost Triumph 7
J TR2/3/3A Finally getting started Triumph 20
Elva164 Finally did another onboard video! Racing 4
J It is driveable! Finally. Morris 8 Other British Cars 8
M Finally Joining the Bugeye club! Spridgets 20
simon1966 Rain cleared up so finally got out. Austin Healey 31
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
vickxxx T-Series Finally MG 3
Sarastro TR4/4A My TR4A finally arrived! Triumph 11
B Scuttle shake finally sorted Austin Healey 23
B Finally - BJ7 painted Austin Healey 3
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
Basil Back to the EType finally Jaguar 5
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
drooartz Finally found one Spridgets 8
L Are 100's finally eclipsing the 6 cylinder cars Austin Healey 6
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
R GT6 Finally Finishing Triumph 19
Sherlock It's driving season finally! Spotted 5
J Finally a fix for the SU pump Austin Healey 5
F MGB Finally got my 78 MGB on the road MG 5
F Spitfire Finally Mobile! Now Grind/Rubbing from Clutch, Gearbox Or? Triumph 5
mgedit General TR Finally a Sniff of Spring Triumph 3
